Question about LG Televison & Video
How to connect wifi to smart tv Lg LM6200
I am not able to connect to wireless network on the tv.does it require a wifi dongle or can i connect directly.
Tanker944
  • 12 Answers
SOURCE: LG Incite: Connect to a multiple-user WiFi network
To enable or disable Wi-Fi
  1. Choose Start, choose Settings, choose the Connections tab, and then choose Wireless Manager.
  2. Choose the Wi-Fi button. If it is turned off, the button will appear as a lighter color and display an icon marked with an "X".
  3. Choose Done.
clear.gif To set up a Wi-Fi connection
  2. Scroll to Wi-Fi and press ENTER. The device will detect available Wi-Fi networks.
  3. Select the network you want to connect to, and then choose OK.
  4. Select Internet or Work, and then choose Connect.
    If you select a secure network, you may have to enter a network key that is provided by the network administrator.
clear.gif To edit a Wi-Fi connection
  2. Choose Menu, and then choose Wi-Fi Settings.
  3. Scroll to the connection that you want to edit, choose Menu, and then choose Edit.
  4. Make changes as needed, and then choose Finish.
clear.gif To delete a Wi-Fi connection
  3. Scroll to the connection that you want to delete, choose Menu, and then choose Remove Settings.
clear.gif To change Wi-Fi settings
  2. Choose Menu, choose Wi-Fi Settings, and then choose the Wireless tab.
  3. Scroll to the connection that has the settings that you want to change, choose Menu, and then choose Edit.
  4. Change any of the following information:
    • In Network name, enter a name for the connection.
    • In Connects to, select The Internet or Work.
    • If the network is a hidden network, which means that it does not broadcast its Service Set Identifier (SSID), select This is a hidden network.
    • If you want to connect directly to another device or computer, and not to a network through an access point, select This is a device to device (ad-hoc) connection.
  5. Choose Next.
  6. On the Configure Network Authentication screen, do the following:
    • Select the authentication and data encryption methods.
    • Enter the network key information or select the The key is automatically provided check box.
      If it is necessary, ask the network administrator for authentication, encryption, and network key information.
  7. Choose Next.
  8. Select or clear the Use IEEE 802.1X network access control check box.
  9. To use Extensible Authentication Protocol (EAP) or smart card authentication, make the selections appropriate to your choice of authentication.
  10. Choose Finish.
Posted on Aug 05, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Lost internet access WiFi and direct
Go to control panel > Device Manager > scroll down to the network devices and click on the plus sign. Highlight the wireless device. Right click on it and choose uninstall. click ok and reboot the system. When windows reloads, it will recognice the new device and want to load the drivers for it. It may ask you if it can search windows update for a fresh driver, allow it to continue. The drivers will load and the correct settings applied. All should be as it should.
Posted on Sep 21, 2009
FixinFax
  • 3085 Answers
SOURCE: What brand USB Wireless Adaptor will work with my LG TV
Any brand of USB Wireless Adapter will work. Netgear, Linksys, etc
Posted on Apr 08, 2010
  • 5 Answers
SOURCE: Connected wireless dongle to LG
Try with same gateway ip & DNS-server ip
Posted on Aug 20, 2010
  • 825 Answers
SOURCE: LG wifi dongle finds my
Wireless adapter finds your AP... It clearly says that your wifi adapter is installed perfectly and working fine...
the issue is with your wireless router...
It is not processing the request given by your wifi adapter...
Either your router in dormant mode, in this state the router will keep on working with all networked computers, but it will not accept any new connections...
Or your router is highly secured that the computer is not capable of establishing a wireless connection with it...
Even if the Hardware(usb adapter) does not support the kind of security that is enabled in the router, you will have the same issue...
It is recommended to go with a WEP kind of security for the router as most of the devices are not compatible with WPA / WPA2 kind of password ...
Also if you have a feature called WPS(Wifi Protected Setup) enabled in your router, it would be better if you DISABLE this feature...
Posted on Dec 11, 2010
How do I get my LG smart tv to connect to Wifi
change your WiFi security setings in your router from WPA/WPA2 to WEP.
Go back to the Smart TV and reconnect to your network with your selected security key.
It may be less secure but it may be the only setting your tv will recognize.
Sep 11, 2017 | LG Computers & Internet
How do i connect my luxor tv to the internet wireless
As far as I know there is only one Luxor TV model that has Internet access (Smart TV) and it comes with a wireless adapter/dongle. Plug the dongle in the USB port of the TV set and follow the instructions in the user guide on how to set up a network connection. Usually, from your remote, go to Menu, Settings and then to Set Up Network Connection. Please be aware that you need to have a wireless modem/router for your home network in order to be able to connect your TV to the internet.
Hope this helps.
Nov 19, 2014 | Computers & Internet
My luxor 40inch smart TV will not connect to Brightbox router viA wifi dongle? Please help
You TV cannot use a wifi wireless dongle. The usb port on your tv is for connecting a usb drive for pictures or movies. There is no place to load the drivers necessary for a wifi or bluetooth dongle.
Apr 02, 2014 | Computers & Internet
My lg tv didn't recognize a wifi dongle
http://www.lg.com/sg/support/product-help/CT20212004-CT20212005-1363223776114
Apr 10, 2013 | LG ANWF100 Wireless dongle
Problem with LG TV LM6200 playing youtube
The small circling thing is the video is buffering. Unless you have a super fast band width, this is very common. Your TV is working fine.
Jun 20, 2012 | LG LM6200 55" Cinema 3D Smart TV
I purchased the lg an-wf100 dongle. It connects to my wifi but is asking for a manual ip entry. I have a 42lg5500 led tv. The manual/automatic field is frayed out, so is the DNS field.
Sounds like your router isn't set for DHCP. Try entering an IP address that isn't in use on your network. You'll find the IP address range in your routers settings. Either that, or set your router to DHCP. Hope this helps.
Regards,
Matt
Mar 16, 2011 | LG ANWF100 Wireless dongle
Don't know how to connect to lg tv with AN-WF 100 dongle to computer home network. It shows both of my wireless computers in the 'My Media' section, but will not connect and says "Failed to connect to...
Hi. Brian...Call LG Customer Care Number @ 1-888-311-3841 (Toll-free) USA. and find instant help to connect LG tv with AN-WF 100 dongle to computer home network. The LG technicians available 24*7 for you.
Feb 14, 2018 | LG ANWF100 Wireless dongle
Televison & Video Logo
394 people viewed this question
