Monitor setup for lg m2352 software - Computers & Internet
Dual smart solution software doesn't work?
You do not need the software to run dual monitors. WIndows 7 has this feature built in.
Feb 17, 2014 | LG 22" FLATRON LCD Monitor
Easy Set Package software is not functional at the LG E2250
I have the same problem. I wrote to LG and here is what they responded:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6464
Easy Set requires proper communication between the software and the monitor in order to work properly. To do this it has to go through Windows and the graphics driver. Not every setup is going to support this. If the dual web mode cannot “see” a monitor it supports, it will be grayed out.
I have an nVidia FX 5500 and latest driver.
So it seams I need a PC upgrade.
May 23, 2010 | LG Computers & Internet
On dual-monitor setup after period of inactivity flatron stays dark and fails to respond, while the old hitachi crt responds immediately
try resetting the setup i mean setting it up again also what happens when you turn the monitor off and back on
Apr 05, 2010 | LG Flatron 295LM 22" LCD Monitor
ForteManager problem (LG monitor software)
I uninstalled the Forte Manager through the control panel as I was having recognition problems with my W2552.
It has solved the problem, and I have had no problems since!
Sep 24, 2009 | LG W2353V-PF 23' LCD Monitor
My eMachines M2352 laptop screen turns off from time to time and then I can no longer use the computer, the internet stops working, the keyboard, the speakers stop playing audio, almost as if the computer...
Sounds like its entering hibernation or sleep. Check your power settings in control panel. If that doesn't correct it look into administrative tools and check the event logs for any errors that will lead you to the correct fix
Aug 30, 2009 | E-Machines M2352 Notebook
Change the contrast on my LG screen FLATRON L1919S ?
see if there is some software cd with it or see if display properties has somthing in setup
Jul 29, 2009 | LG L1920P 19" LCD Monitor
Monitor configuration
Did you also install the LG software and LG Drivers correctly?
With my LG flatron i received a piece of software to optimize my settings and even calibrate the monitor. I run win XP ME.
Jul 04, 2008 | LG 22" Widescreen Flat Panel LCD Monitor
Calibration
Have you tried adjusting the "Adobe Gamma" via the setup from your control panel?
Oct 12, 2007 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
