Question about HP Color LaserJet 2550n printer + HP Color Training and extended warranty ;U4929E, Next-Day exhange...
Triangle with caution sign constantly flashing / no print
Will not print or re-set even after power down
the light is still flashing
    Problem Solver:
  • 4 Answers
Paper jam, top cover is open, out of paper, fuser is bad, or paper did not pickup. All but the fuser is consumer repairable.
Posted on Feb 16, 2009
Flashing indicators on my audi a3 dont flash but stay on constant
change it. most likely contains the flasher for turn signal also
Jun 03, 2014 | Audi A3 Cars & Trucks
Porsche Indicators Lights Flashing
switch off the flashing warning light to the right6. It has a red triangle on it.
Apr 21, 2013 | 2001 Porsche 911 Carrera
Resetting waste in absorber code for IP4900
You ink absorber is full
1. Download canon service mode tools v3400 from the net.
2. Set the printer in Service Mode: - power OFF the printer bu Power button. Dont disconnect power cable
- connect the printer by USB cable to the PC.
- press and hold Resume button (red triangle in the red circle) and press Power button
- hold both buttons until power on indicator will light then release resume button (dont release Power button) and press Resume button 5 times
- release all buttons - the printer will blink few times with green light and will then light green constantly. You have put the printer in Service Mode now and you can now run the Service Tool. (If the printer is still blinking by green - you have some other errors in printer and you have to fix them first, because the Service Tool will not work if the printer is not put in service mode - green light is constant)
3. Run the Servicetools V3400.exe program.
4. Select the connected USB port number from USB PORT
5. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
6. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Print EEPROM information to confirm that the value is properly set to the EEPROM.
Jan 18, 2013 | Canon PIXMA Office Equipment & Supplies
There is an amber triangle and arrow anticlockwise what is this sign for
Its the ESP, Electronic Stability Programme.
Solid light all the time - Check the system hasn't been turned off (switch near gearlever). If not, proceed with caution to your Volkswagen dealer
Light flashing sometimes when driving - This indicates the wheels are spinning and the traction system is trying to control. Reduce acceleration.
Hope this helps.
Owen.
Jan 10, 2013 | 2000 Volkswagen GTI
The error light on the Epson TM-T88IV keeps flashing whats wrong with it?
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Oct 23, 2009 | Epson TM T88 Thermal Printer
Triangle on front constantly on orange. wont scan nore print
Replace or refill the VO51 in cartridge, it's out of ink.
Apr 29, 2009 | Office Equipment & Supplies
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Orange flashing light on printer
No the ink is not to low you could try removing the ink cartridges and using a soft cloth wipe clean the little gold contacts on the cartridge and also the printer. Is the ink cartridge a original one if not even though the HP software states that there is 20% in there the likely thing is that the cartridge is empty replace and this should be OK.
I hope the first suggestion works for you as will not cost any money.
Thanks J
Jan 12, 2008 | HP DeskJet 930c InkJet Printer
258 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
