Question about Crunch BlackMaxx BMX2250 2 Ch 1000W Amp Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
I recently installed a Crunch BlackMaxx BLX2250 in my car. It played fine for two days and then all of a sudden there was no sound. But randomly it will thump wheter the RCA's are hooked up or not. I've checked all the wires, there are no bad connections. I've even checked the voltage with my meter. Could there be a short in the remote wire? Or does the Red Light mean that the Amp is blown?
I have the same problem as mike, how to get it reset?
Posted on Oct 19, 2011
I have the same problem i have a crunch 1500 wat amp, and i turned on the car and the subs made this little thump and then wouldnt play, ive checked everything fuses and disconected everything and put them back, but it still has the protect light on, i dont know how to reset it
Posted on Jan 16, 2008
  • 30 Answers
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Posted on Aug 06, 2007
Does crunch blackmaxx take aux for iPhone?
The amp is a discontinued model, but I do think I found the specs on it. It will produce :
350 Watts X2 @ 4 ohms
700 Watts X2 @ 2 ohms
1,400 Watts X1 @ Bridged at 4 ohms
It is designed to be ran inline between your stereo and a set of, or a single, sub woofer.
This could be a significant amount of work for a beginner in car audio, but it can be done.
I would do a little research and decide if you want to use this amp. Join in on forums like http://www.caraudio.com/forums/forum.php, and http://mobileaudioforum.com/forum/forum.php to learn what can be done, and how to do it. good luck.
Jan 19, 2014 | Crunch Car Audio & Video
What size fuse goes in the 2 side ports
The amp delivers from the factory with 2 40amp fuses.
Mar 28, 2011 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
I have a DA 1200.5 5 channel amp. It stopped
diconnect all your speakers from the amp and see if the light turns green. if it does, reconnect one speaker at a time to find out what speaker is making the amp go into protect mode
Feb 24, 2010 | Crunch BlackMaxx BLX2000D Car Audio...
Stock red light protection in my crunch amp
it is most likely a blown mosfet inside the amp
Aug 28, 2009 | Kicker SX400.2 Car Audio Amplifier
Need help (autotek mx1300)
find the input gain controls, theyre usually recessed into little holes, so you have to stick a small regular screwdriver into each of the holes to turn up both the left and right gain controls.
May 15, 2008 | Crunch BlackMaxx BLX2000D Car Audio...
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
I was wondering
the cost for a blackmaxx blx1000d amplifier can be obtained at a cost of US$281.00 at www.4boxers.org
Aug 07, 2007 | Crunch BLX1000D Car Audio Amplifier
Amplifier stop working
this problemis your amp is dead powerflux you need the asistance techinic
May 27, 2007 | Crunch BlackMaxx BLX2000D Car Audio...
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Crunch BlackMaxx BMX2250 2 Ch 1000W Amp Car Audio Amplifier Logo
854 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Tygh Duval
Tygh Duval
Walter Dominguez
Level 1 Expert
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
