Question about HP LaserJet 4 plus Printer
Replaced toner is printing very light.
I replaced my toner in Jan. and ever since then, the printing is as light as the old one. I have taken it out and shaken it but there is no difference.
  • 1 more comment
  • gullenj Mar 03, 2009
    Similar problem with lighter print, but not all docs. PDF files and emails thru hotmail are very faint. I replaced the transfer roller - not much difference. Settings: RET=Dark and set to level 5 for Density. Tried switching to various drivers since there are many with LaserJet 4, 4 plus, 4/m, PS etc. with no change. Test print page is strong and black thru out. A month or so ago I came across a fix, I thought it was on this site, that suggested and I downloaded a patch related to PDFs. Old tech printer not understanding new tech PDFs, etc. ?? Anyway, I didn't know how to implement the add on. I tried it as a driver file w/out success and have since lost the file and the link. Any help would be greatly appreciated.
  • John LeFebvre May 11, 2010
    Also if it is not a genuine toner it could produce bad results. You get what you pay for is true more often that not.
    I take it none of the settings on the printer have changed, like turning on Economy mode?
  • sdtech May 11, 2010
    2 things - 1 maybe a bad toner - these are old printers and sometime the toner has been around for a long time. 2 the fuser could be getting weak - replace fuser - check the page count with the selftest menu and see how many pages it has printed - if around 100,000 try a new fuser
If the print quality is the same as the old one - light laser is dirty and/or transfer roller. Fuser would NEVER cause light copies -but rather, dark, smudgy copies
Posted on Mar 01, 2009
How do I know which toner is empty on samsung clp315
  • 1.Log on to your computer and print a test page to the printer. Click on the "Start" button, choose "Control Panel" and then "Printers and Faxes." Right-click on the laser printer, choose "Properties" from the drop-down menu and click the "Print test page" box.
  • 2.Look at the quality of the print on the finished page. If the print is light or faded, the ink cartridge is probably empty or at least empty enough that it should be replaced. You can try to get some extra life out of your toner cartridge by taking it out of the printer, shaking it vigorously and putting it back in. Under normal printing loads, this can give you one to three days of additional printing capacity.
  • 3.Open the printer cover and carefully pull out the toner cartridge. Set the cartridge aside while you open the box containing the new toner. Pull the new toner out but do not yet remove any of the packaging materials. Compare the weight of the new toner with the old one. If the old toner is very light, it is nearly empty and should be replaced.
  • Sep 22, 2011 | Samsung CLP 315 Laser Printer
    I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
    I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
    Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
    Nov 01, 2010 | Samsung ML 2525 BW laser Printer
    Intellifax 2800 does not register new drum. I put in new drum and it is extremely light copies and is stll telling me to replace drum soon
    If you replaced the drum with a new one, then a special plastic piece with slots in it will be ejected. This will reset the "Replace Drum" message. Now the light print is probably due to the toner needing replacing. When you put in a new drum, it needs new toner too. Unfortunately, most people replace the toner into the old drum, which does no good and becomes wasted. NEW DRUM NEW TONER. Now if you have replaced the old drum with another old drum, you won't get the reset done properly and the new drum won't load any toner either. Perhaps you accidentally removed the plastic sheet when you replaced the drum? Well then, find the piece and run it through the paper feed, it will then reset. Best of luck
    Oct 06, 2010 | Brother IntelliFAX 2800 Laser Fax
    I have a Brother 5240 printer. The toner light
    Try this... it reads the level of the toner and can become faulty. This clears it.
    1: Turn off power and remove toner/drum
    2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
    3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
    4: Turn off printer, remove tape from lever, replace drum and turn back on.
    Jun 24, 2010 | Brother HL 5250DN Laser Printer
    Toner quality is still light after installing new toner cartridge
    No, if the old one prints better than the new ones, it is a toner cartridge problem. Are they remanufactured /compatibles? I suspect it is a problem from the supplier
    Mar 09, 2009 | Brother HL-2040 Laser Printer
    TONER WAS LOW STARTED PRINTING ENDLESS PAGES OF STRANGE CHARACTER
    hi!!!
    ok try to re-installed the printer driver
    or replaced the usb cord
    Nov 10, 2008 | HP LaserJet 1320 Printer
    Lexmark E250d
    I had the same problem today with my printer. All of a sudden, the first and fourth light lit up. I contacted Lexmark and they said my toner cartrigde needed to be replaced.
    The problem is caused by the little chip under the cartridge. I replaced the chip with an old one I had on another cartridge and I got the printer to work again.
    You can buy a replacement chip from Lexmark or from a jobber selling replacement cartridge or toner refills.
    Hope that helps.
    Sep 30, 2008 | Lexmark E250dn Laser Printer
    New toners and drums, but flashing amber error light - won't print now
    Have you replaced the printer drums? The status monitor will tell you what percent they are at (similar to the toner cartridge status). This fixed my problem before.
    Jun 07, 2008 | OKI C3400n Laser Printer
    Stopped printing after I installed new Toner!
    If the new toner is original, your unit just burned the fuser. If it is under warranty, any Samsung Authorized Service Center will gladly replace it for free.
    Oct 22, 2007 | Samsung ML 2010 Laser Printer
    HL 5250 dnt
    hello Imarsh1 it seems to me that the problem is intermittent. try removing the toner and the catridge, vaccum or clean toner residue of the visible inside of the printer, just in case is a sensor problem. also check to see if you have replaced the printer tonner with the right one by checking the model no for compactibility.
    Aug 10, 2007 | Brother HL-5250dnt Laser Printer
    HP LaserJet 4 plus Printer Logo
    257 people viewed this question
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
