Question about GE Refrigerators
How do i get ge refrigerator pfe29psdass out of demo mode
3 Suggested Answers
SOURCE: ge profile refrigerator
my refrigerator model #gss221fphbb not cooling
Posted on May 12, 2008
rogrrabbit
  • 986 Answers
SOURCE: We just purchased a ge profile refrigerator today,
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Posted on Jun 14, 2009
HOW DO I PUT A GE 31949 OR 3977 SIDE BY SIDE REFRIGERATOR INTO DEMO MODE?
Those numbers are not good model numbers. If you have the owners book it should tell you or go to GE.COM and read the manual off their site. It probably just a matter of pressing 2 control pads at the same time for a set number of seconds.
Mar 27, 2015 | GE Refrigerators
Take PFE29PS out of demo mode
Hold the lock and precise fill buttons for several seconds and a prompt will appear to disable it.
Sep 17, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
How to put refrigerator into demo mode?
Hello friend, that's a great question!
In order to put your Frigidaire refrigerator FGHB2866PF into demo mode you would need to push and hold the "up arrow" on your freezer and the "down arrow" on your refrigerator for five seconds. Once your appliance has went into demo mode both the refrigerator and freezer display should read 77. Hope this information helps. -Matt
Jul 21, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
Resetting the demo mode
turn off with OFF sw.
Press WARMER / COLDER sw for 5 seconds
While maintaining warmer / colder turn ON with ON sw.
SHOULD NOW TURN ON
May 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Floor model will not come out of demo mode.
If following dirctions from your owners manual does not do the trick. I would call for a tech to look at it. Every thing is control by dispenser board on a PSS26P
Jul 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Demo Mode
try unplugging it then plug it back in
Jul 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge profile refrigerator
May 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Microwave DEMO MODE
I just bought a condo with a GE Spacemaker Mod# JVM1860SD
that was stuck in demo mode. (This mod# has been replaced by the JVM1870*** series)
I called GE twice in two days, and finally got someone who had the solution (and it worked):
  1. Unplug the unit for at least 30 seconds
  2. Plug the unit back in DO NOT SET THE CLOCK
  3. While the unit is still "booting up" and the display screen is lit with gibberish, HOLD THE POWER LEVEL AND THE ZERO BUTTON for at least 5 seconds.
  4. After 5 seconds, the screen will display "demo mode off"
It messed me up at first because the power level and zero pads don't beep when the unit is booting up... but it worked.
- Again, this is for the GE Spacemaker 1860-1870 series models only - The women who gave me instructions said she had different demo mode unlock methods for the 1400, 3670, 2070 etc... so call GE if you have a different model.
P.S. my model looks like this - the keypad setup is key http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JVM1870SK&SITEID=GEA
Mar 01, 2007 | GE Advantium SCA2000B Microwave Oven
Refrigerators Logo
351 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
