Question about LG Heating & Cooling
We have an LG (LS-D2461HS) and the remote control is broken where can i get a replacement remote
4 Suggested Answers
  • 4 Answers
SOURCE: I do not have the manual for my LG LS-D2461HS air conditioner
Look at
www.canbysales.com/support.htm
Servicemanuals
2005
sevicemanual LSC091PMA / LSC121PMApma
Posted on Jan 20, 2009
  • 400 Answers
SOURCE: I cannot find the swing button on my remote for my LG LS-D2461HS
The swing button is usually on the right side of the remote and has three little arrows pointing toward an arc or half circle line with arrow up and down. If you press this once it will go on auto swing, you can wait for the louvre to get to the right position and then press it again to stop in that position. You can also on some models change the left/right airflow direction in the same manner or manually direct the airflow to one side. If all fails, you can gently manually position the louvre up or down.
Posted on Mar 05, 2009
heatman101
  • 43501 Answers
SOURCE: LG LS-D2461HS air con on turn on just blows air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Jun 27, 2011
LG LS-D2461HS air con on turn on just blows air out. no heat or cod air at all even when temperature setting increased to 30 degree for cold air.
heatman101
Jun 27, 2011 | LG Heating & Cooling
Can I purchase a new remote control?
If your remote is problem, don't operate a/c with manual switch in indoor unit or without control. Plz go with new remote. Thanks.
Jan 28, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Lmv240he & lav181cnw
I searched the website but could not locate the literature for that particular unit. I recommend you contact the manufacturer's technical support department. They should be able to email you the manual and direct you how to obtain replacement remote controllers.
Technical Support
For technical support on a DFS, PTAC or TTW Product call 888.865.3026, then press 2.
I hope you find this helpful with your endeavor. Good Luck! :-)
Mar 08, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Cant turn air con of with control
if the remote is lg it haven't code the eye of the plate has burned
Feb 21, 2009 | LG LS-L1210CL Mini Split Air Conditioner
On your email you have the model down as LSC121PMA - this is not the model I posted my query on, it ws the LG LS-D2461HS, and no my query is not solved.
Dec 13, 2008 | LG LSC121PMA Split System Air Conditioner
LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Jun 24, 2008 | LG LS-L1210CL Mini Split Air Conditioner
No Display on controller
Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
18 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
