Question about NRS Brondell Swash 450 Toilet Seat - S450-EW - White
Wash heads on Brondell swash 450 will not come out
Yes we have water, yes the power is working, it is a elongated type,
how do we find a service center?
  • Anonymous Apr 17, 2009
    same thing here
  • 33 Answers
Copy and paste this into Google or any search engine!
http://www.brondell.com/dealersLocator.php
Posted on Jan 28, 2009
I have this model water heater. The past few days i haven't had any warm water and ive been hearing my water heater make strange sounds. I look on the little box and there's a light blinking 3...
Yes.
Copy following link for service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Plug blower in separately and see if blower motor functions. This will eliminate blower as suspect.
Have plumber check wiring, test and replace blower temperature switch, test and replace pressure switch, and conduct routine maintenance
Apr 04, 2013 | Bradford White M1TW40S6FBN 40 GALLON...
Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
Feb 08, 2013 | Water Heaters
Rheem 21VP50-1P - power vent running non-stop.
Rheem does not post service manuals, but other manufacturers do.
Copy following link for troubleshoot by type of gas control valve.
Also, scroll up on same page, on right side for heading title 'Pressure switch' for troubleshooting the pressure switch.
Don't forget to check anode rod to protect steel tank from rusting.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
Oct 12, 2012 | Rheem Water Heaters
Electric water heater doesnt heat anymore there is power getting to the water heater.
You posted under electric water heater but don't give type of heater or brand or voltage.
For most types and brands of tank-type electric water heater, open following link for full troubleshoot.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If this is a tankless water heater, or boiler-type, or indirect, or hybrid water heater, then add a comment with brand, type and voltage for possibility of more help.
Add a comment any time.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 02, 2011 | Water Heaters
I have a toto wash let S#W 824 and would like to download the user manual. I bought it used with no manual.
Try the wizard of OZ after all he helped Dorothy and friends!!! On a serious note try the TOTO website?? Thing that make you go HUM....
Aug 20, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
Swash 800 wands stopped flushing.
Hi There,
Just call Brondell toll free at 888-542-3355 and they we can trouble shoot the problem. If it's in warranty, repairs may be covered and outside of warranty, discounted servicing is available.
Feb 04, 2010 | NRS Brondell Swash 800 Bidet - Electronic...
THE WATER KEEPS FILLING PAST THE OVERFLOW.
Replace fill valve. Fluidmaster works quite well and is very adjustable.
Jan 21, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
Toilet Question
Yes, it will run up your bill! Sounds like the float is hanging up. Take tank lid off and flush, watch the float and if your tank fills quickly but does not stop, bend the float arm to angle the float down further, this should allow your water to stop coming in much quicker. The other possibility could be if the plug at the bottom does not seal correctly after flushing, if so, the water will leak until the plug sits down all the way.
Apr 11, 2009 | Kohler K-4709-96 C3-200 elongated toilet...
Toto C100 Toilet Washlet Seat
There are two types of bowls as far as toilets are concerned...elongated and round front. The seats are interchangable as long as there isn't anything different in the way the seat is mounted to the toilet. As far as I know and my experiance with both brands, I can't see any reason why it would not work.
Apr 05, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
NRS Brondell Swash 450 Toilet Seat - S450-EW - White Logo
134 people viewed this question
Top NRS Water Heaters Experts
Paul Carew
Gil Shultz
Are you a NRS Water Heater Expert? Answer questions, earn points and help others
