Question about Sony FD Trinitron WEGA KV-34HS510 34" TV
The electronic repair shop my Sony has been for more than a year states they can not get a High Volt Transformer to fix the TV- Does this sound legit?
  • 31 Answers
Yes and Sony says to replace the whole board (sony D board) very expensive!
Posted on Aug 27, 2009
I have a Sony model KV-32S26 that will not turn on, been sitting for about 2 years. Had a tv repair guy tell me it was the flyback transformer. If that's the case, can I replace it myself? Thanks
1) You must test the a) fuse b) c.breaker inside c) diode, d) rectifier e) transformer f) filter. g) IC. regulator voltage and test it. If the problem persist you must go to the horizontal problem by lack of RASTER, now you test the transistor horizontal power, flyback. If you have some experience with the electronic you can try. If do not, better go to the repair shop Tv. Since you can have a electric shock by H.Voltage discharge.
God bless you
Oct 11, 2012 | Sony KV-32S26 32" TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
When I turn on the tv, it makes a sparkly sound and shuts off.
You probably have a high voltage failure causing the TV to sense the overload and shut off. There is about 30,000 volt required to light your picture tube focus the picture. If there is a failure anywhere in this circuit you will get the hissing noise and occasionally an ozone smell. I recommend you contact a TV serviceman to diagnose and repair this problem.
Oct 08, 2009 | RCA D52W23 52" HDTV CRT TV
7 flashes on my 34HS420 Sony TV
7 blinks indicates problem of Horizontal deflection failure. Possible cause can be Horizontal Out Transistor and / or Fly-back Transformer shortage.
If you have TV repair experience and electronics knowledge background, let me know to guide you more OR take TV to local TV repair shop for proper fix.
Jan 06, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My CT-32SL14 32" TV has a high pitched Random BEEEEEEEEPing sound
prob high volt transformer tech may be able to repair replace cost high. 200 orso
Dec 01, 2008 | Panasonic CT-32SL14 32" TV
Panasonic television
This is not something that you can fix, the sound is the high voltage section with the horizontal output transformer. The reason is a possible flyback transformer failure or the high voltage diode is bad. Most electronic shops can fix it.
Nov 26, 2017 | Panasonic TX-28CK1 28" TV
Experience
So you don't have experience of tv repair. I would recommend you to get help of local repair shop or find a friend who has knowledge of electronics.
You need KV-36FS120 service manual, tools like volt meter to test voltage etc, knowledge of parts recognition, must know good solder work to replace defective parts what ever found in tv, must know and recognize high voltage area in tv etc.
what do you think now, let me know.
Oct 11, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a Sony WEGA KV-27FS120 tv
Have you ohad electrical prooblems or lightning in your area?
Im sorry to inform you that a red light blinking is an indication that the main power supply is good BUT the sweep supply has a problem .. Most likly the high voltage transformer as well as the horizontal transistor is bad. if you have no solid state repair experience, you will not be able to fix this set on your own. You have to troubleshoot the board and test the circuitry.
I could be simple as a fuse but unlikely. Is there a Sony repair shop in your area?
Aug 18, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Trinitron Vega KV-34HS420
it's better if you bring you're tv to sony service center and ask to an authorized repairman
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture or sound just a high pitch beeping noise
Your problem is a bad sweep power supply or the horizontal sweep circuit has a short in it such as a bad horizontal output transistor as well as the high voltage flyback transformer. These are not problems that should even be concidered to be repaired or attempted to be repaired by an untrained person in solid state electronics. Please seek out a trained service person to estimate the TV for you as there are no user parts inside this set, and a TV set is not a place to be experimenting around inside of.
Oct 07, 2006 | Philips 20PT6245 TV
Sony FD Trinitron WEGA KV-34HS510 34" TV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
