Question about Emerson EWF2703 27" TV
TV Channels I can't get my television to go any higher than channel 69 however, my dish satelite needs for the tv to be on channel 73. It worked earlier on that channel, now I can not get back to that channel. Any suggestions.
SOUNDS LIKE WHAT HAPPENED TO ME WHEN THE CHANNEL GOT ACCIDENTALLY BLOCKED AS AN UNUSED CHANNEL CHECK YOUR MENU ON REMOTE FOR ADD AND REMOVE CHANNELS AND RELOAD THAT CHANNEL AS INSTRUCTS IN MANUAL FOR THE TV
Posted on Jul 18, 2007
SOURCE:
Why will my rca trflat not go past cannel 69
Hi there. Maybe your TV is not equipped for S channel reception.
Channel 73 falls into the S band; (21-69 is the normal UHF band.)
However in most cases, you must choose in wich band you scan your channels; (H, or S) I cannot imagine that this modern TV should not be equipped for S channels. Try manual channel search, where you'll probably find this possibility.
Oct 03, 2014 | Televison & Video
I'm tring to change my sylvania tv 6424tfs to channel 73 it's not letting me
It sounds like the main system control memory IC to your set is faulty. Even though, this IC is very small in size, and very cheap to buy, the function to it, when the TV is switched on is great. It will be best to contact any service technician in this case. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 10, 2013 | Sylvania 6424TFS 24" TV
Hi, my Phillips was hooked up and working fine directly to the DISH receiver using the HDMI 1. I moved and had to put the DISH receiver in another room and ran a coax cable to where the TV is now using...
Hey murphypat321,
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at thomas.faust@dishnetwork.com if the problem persists.
Tommy Faust
DISH Network
Mar 09, 2011 | Philips 42PFL5332D 42 in. LCD Television
I can't go past channel 69 and I need to go up to at least channel 73
how old it the t.v. - most t.v.s are at least 181 channel compatible..hodge-podge words..in lay terms you have to have the capability on the t.v. to support X nbr of channels...also check to see if you have the menu set at cable or air...setting needs to be on cable
Jul 07, 2009 | Emerson EWF2004 20" TV
Need to find channel 60 or 73
The TV is capable of tuning VHF channels only.
Jun 27, 2017 | Goldstar GLV-B1000 4 in. Television
I have a Samsung 27" TV and need to set it on channel 73 to get a picture from my Satelite Dish. The highest channel the tv goes to is 69.
Set the TV to cable tuning mode and use that channel 73. You have it set for air now so it can only tune to channel 69.
Apr 26, 2009 | Samsung TXN2771HF 27" TV
Settting tv to a higher channel for cable`
Most TVs have a choice of air or cable in the menu portion of the tv. press menu go to setup and from there you should see an option that says air/antenna or cable. You will have to either toggle to get the air selection or highlight it. Then you should be able to get to channels you need.
An easier solution may be to go to the Dish receiver that controls the image on the tv you can't get to 73. With tv and satellite on (make sure both green and blue lights are on) press on your Dish remote #1 with the green tab on the bottom the following sequence: MENU - 6-1-5. tHIS WILL TAKE YOU TO THE MODULATOR SET UP PAGE. Move the highlight from cancel to the mode section an highlight AIR and press select. Then move the highlight back to the right to DONE and press select. Press cancel three times or view live tv. then go to the other tv and put it on ch 60.
Hope this assists you.
Sep 09, 2008 | Symphonic ST420FF 20" TV
Does tv go higher than channel 69
In 1998, UHF-69 was highest channel. you need that TV which has today's technology.
May 29, 2008 | GE Televison & Video
Switching from TV to CATV
it sounds like the tv is already in cable mode, and that it is a older tv. some older tv's will only tune in so many channels. yours going up only to channel 69. if you have the remote for this tv, try punching in channel 73. if it doesn't tune in, then the tv will not recieve channel 73.
good luck
wg
Feb 05, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Jan 21, 2007 | Sony KV-36XBR250 TV
Emerson EWF2703 27" TV Logo
354 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
