Question about CyberPower Cps175su Power Inverter
Cps 175su usb port powers down - CyberPower Cps175su Power Inverter
The usb port only gets power for a few seconds at startup. it wont read my usb Harddrive
When an USB port delivers power o a PC, it only can handle 500 mA. Not more. But not all PC's do have power on all USB ports.
When the HD has a higher demand then the port on the PC can deliver, the PC will shut down the supply for that port, to protect the PC.
Mar 27, 2015 | Power Computers & Internet
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
My powered USB port on my Dell Latitude D410 shorted out. Can this be repaired/replaced?
The USB plug will need to be removed from the computer, if luck is with you the computer will work, if no part is available, use a none powered USB hub on a spare port if available to run your applications.
Jun 23, 2012 | Dell Latitude D410 Notebook
The scaner to check the codes dont come on when conecte to it
OBD-II ports not communicating with a code scanner when caused by the CPS is because the CPS has failed. If the CPS is failed, the engine will not run.
Try another brand or model of code scanner.
May 03, 2012 | 2002 Chevrolet TrailBlazer
How do I connect a 180e serial cable to my usb computer when Artlink and CPS software specify serial port?
I've not successfully managed this ... trouble-is that although you can get USB-to-serial converters, most computers that only have USB ports do not properly 'recognise' COM ports, which is what your Artlink software expects to talk to. I still use an old PC with a 'proper' 9-pin serial port on the back in order to talk to the old Artista range of machines. One of the drawbacks of a 'throwaway' PC industry that expects the rest of the world to continually update everything in response to new interface standards!
Oct 08, 2011 | Bernina Artista 180
My Bernina Artista 180E no longer works with updated Windows. Is it possible to upgrade so that I can still use my 180E and not have to buy another machine?
Just use the free download software from Bernina called Artlink. I used it along with a USB to Serial converter cable to connect to the machine. Works wonderfully. Allows me to still use my old Artista designer software if I want to on an older machine and then when I want to actually transfer the designs I use the laptop with the USB cable.
Feb 01, 2011 | Bernina Artista 180
The harddrive wont power up witout the power cable attached to an extra usb port but now I keep getting a message saying USB device not recognised and when i go to the device manager it says unknown usb...
You need the power from the 2 USB ports in order for the Drive to have enough Power.
Try moving the USB Ports to another Port or Flip Flop the 2 USB Cables.
Another option is to uninstall the unknown device. Remove the USB Cables, Uninstall Shut Down, Re-Start.
NOTE: Certain Ports on your System are USB 2.0 and some are not. Try to use the 2.0 port listed in the Manual... it will be faster and may carry the Power.
Jan 07, 2010 | LaCie 160GB Little Disk USB2/FW400 160 GB...
USB power pulled by Dictaphone 0PSHM01-006?
A USB port supplies 5v
As the OPSHM01-006 was made to work with a standard USB port it should only pull current equal to what a standard USB port is rated at.
If when the machine is plugged in it causes the host machine to get sick or it will not operate there is a component down in the scanner
Jun 25, 2009 | Computers & Internet
Power surge on hub port a usb device has exceeded the power limits of its hub port there is nothing connected to my computer
I don't know how old your system might be or how many USB controllers it has on the motherboard, but understand this...
Theoretically, one USB port can support up to 999 "daisy chained" devices.
With that said...the way a USB port is implemented on a motherboard, manufacturers enable two or four ports to be working off of one USB interface. Those ports you see on the front of your computer are most likely connected to just one USB interface on the actual motherboard and that's why you always see computers with USB ports located together in pairs.
With that in mind, you're USB ports are connected to what is referred to as a "hub"(that motherboard interface), which only outputs so much power. If one device or many devices attached to this "hub" exceed the power output of this "hub" then it will either back down to USB 1.1 speeds or it won't function at all. That is why some USB accessories require their own wall adapter, because the USB can't supply all the necessary power for it.
So one of two things has happened, either your USB port is fried or you introduced a new USB item to the "hub" that surpasses the power requirements of what your USB hub can output once you plug in your mp3 player.
You can troubleshoot by unplugging all un-necessary USB equipment and try only that port again. My assumption is that the USB hub is fine but the actual usb port you use might be damaged.
Good luck.
Mar 12, 2009 | Acer Aspire One PC Notebook
Usb ports
hi im josh in cebu phils. may i help you?
Friend if you put something like usb or etc.it shut down. the problem is your power supply.your power supply dont have enough power to gve the new installed device thats why it shuts down.
Feb 21, 2009 | Asrock P4V88 (P4V88 RAID) Motherboard
CyberPower Cps175su Power Inverter Logo
27 people viewed this question
Top CyberPower Televison & Video Experts
Electro Med Services...
Are you a CyberPower Televison and Video Expert? Answer questions, earn points and help others
