Question about Brother MFC 420CN All-In-One InkJet Printer
Will not print black, only color
I cleaned the cartridges and replaced a new black ink, but still only prints in color, no black. Any ideas?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Don't print the black color
Doing reference on your issue. Double check the ink cartridge to make sure that the cartridge is correctly installed. Also be sure that the black ink cartridge used is compatible with the machine.
The next thing to do is a cartridge cleaning as the belief is that the print head is blocked. If you have done a thurough cleaning, the next thing to do is replace the black ink cartridge to be certain the ink cartridge is not faulty.
I have included print head cleaning instructions in case you have not done this cleaning process.
here is some information from the Brother support site:
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may solve the problem.
Cleaning the print head may solve the problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then choose ALL.
When the machine completes cleaning the print head, press Color Start. A Print Quality Check Sheet will print.
Brian
Jan 22, 2011 | Canon MX700 Office All-In-One InkJet...
New ink cartridges not printing
The ink cartridges that you replaced are brand new or refilled ?
Thanks
Proton
Sep 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Black ink cartridge not empty, but won't print black...
Try running the cleaning tool included with the HP diagnostic software for your model printer. If that doesn't work, try cleaning the ink jets on the black cartridge directly with an alcohol swab. If this still doesn't work and you're sure that you have the correct model HP cartridge installed properly in the printer, you may have to replace the black cartridge with a new one to see if the cartridge itself is defective.
Oct 02, 2017 | HP PhotoSmart C4480 All-in-One Printer ...
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP 6940 color cartridge light will not stop blinking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I might have an idea why this is happening....The print cartridges might need cleaning...
Follow the steps below to do this....
Step one: Remove the black, photo print cartridge, or the gray photo print cartridge
NOTE:
The black, photo print cartridge, or the gray photo print cartridge is in the right side of the carriage. -Lower the cover of the product.
-If the print cartridge status light flashes, proceed to Step two: Replace the print cartridge.
If the print cartridge status light is off, proceed to Step three: Manually clean the print cartridge.
Step two: Replace the black, photo print cartridge, or the gray photo print cartridge and remove the tri-color print cartridge
- Remove plastic tape from new ink carttridge CAUTION:
Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper electrical contacts.
NOTE:
The tri-color print cartridge is in the left side of the carriage.
-Lower the cover of the product. -If the print cartridge status light stops flashing, proceed to Step three: Manually clean the print cartridge.
If the print cartridge status light still flashes, replace the tri-color print cartridge. If the issue continues, service the product.
1. Gather the following items to clean the print cartridge and carriage:
o Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
o Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
o Sheets of paper or a paper towel to rest the cartridges on during cleaning.
2. Open the product cover, and wait until the carriage stops moving.
3. Remove the print cartridge, and place it on a piece of paper with the nozzle plate facing up.
NOTE:
Clean the contacts quickly so that the print cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
4. Unplug the product.
5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
6. Clean the print cartridge contacts. Do not touch the nozzles.
7. Clean the contacts in the carriage, inside the product.8. Either let the print cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
9. Reinstall the print cartridge.
10. Plug the product back in.
11. Close the product cover.
Good Luck!
If there is anything more I can do for you please let me know if not and the problem is solved please rate it, Thanks, JCE
Apr 14, 2009 | HP Deskjet 6940 InkJet Printer
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
