Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up
I have a profile side by side model tfh30prtabb and ice keeps forming on the floor of the freezer and every now and then the temp goes up like five degrees on both sides can you help me out john
I had that problem and just got off the phone with the GE help line. I had a LOT of ice building up and did not realize that eventually it hit the bottom of the bottom basket, thus preventing it from sliding back all the way. This eventually prevented the freezer door from closing tightly, so the problem quickly escalated. The man on the phone told me to melt the ice on the bottom with a hair dryer until I could get it all out, then be sure that the DRAIN LINE is also opened up. He said to shoot in a solution of 2 cups hot water with 1 t baking soda to force the line open so that it does not start building up again. The problem for me is that I cannot find the drain.... hope this helps!
Posted on Jul 21, 2009
Same repair as water leak on floor. unplug, remove back inside panel of freezer, clean out drain hole.
Posted on Jan 28, 2009
I have a GE profile side by side refriderator. The freezer is working(temp is below zero on coldest setting, but the refridge is warm, ranging from 36 -59 degrees depending on the shelf. (this is on the...
the ice is caused from the frozen drain in the back. the cold coil is also frosen / this stopes the air to the fresh food .. so defrost the freezer and ck the heater and defrost termator . . you may also need the main control that has the defrost timer on it . located on the back of frig.. hope this helps . mm
Jul 11, 2011 | GE Refrigerators
My freezer has dropped in temp to -6 and my refrigerator is rising in temp and only blowing minimal cool air. The fridge is less than one month old.
ck the back of the freezer / look for ice build up / if evap coil is blocked the fresh food side isnot getting cold air and the tempt of freezer is dropping . is sounds like a defrost problem caused by main board failure or heater / defrost themo . / fresh food will keep getting warmer and soon the freezer will also .. mm
Oct 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water dripping inside of freezer, forms ice-cicles, water doesn't dispense and temp. rises on both freezer and refrigerator.
Check rear inside wall of freezer for frost build up, this prob is an indication that you have a defrost problem, like a bad defrost heater or defrost control.
Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Fridge temp goes up and ice forms in fridge
CHECK THE BAFFLE IT MIGHT NO BE OPENING OR CLOSING PROPERLY, THAT`S THE SMALL DOOR LOCATED @ THE LEFT UPPER CORNER OF THE FRIGERATOR
Aug 19, 2009 | Samsung Refrigerators
Monogram refrigerator can't keep temperature constant
We need to look behind the rear panel in the back of the freezer and need to look at the mother board on both sides. Will need to unplug and begin. Let me know, Sea Breeze
Aug 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer, water problem
you have a frozen defrost drain, first of all defrost all of the ice out of the drain pan behind the grate, once the ice is gone you'll see a drain hole that goes thru the floor of the refrig. you need to flush some hot water thru this drain.
I use a big syringe filled with hot water to do this it will force any sludge build up out of the drain tube into the drain pan.
kind of an easy fix even if you aint 10=)
Dec 20, 2007 | Refrigerators
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Ice forming in bottom of freezer
Rita, your drain hole is frozen over and when your refer goes into defrost the water is running out into the cabinet instead of down the drain hole. Remove the evaporator cover and poor some boiling water in the evaporator drip pan. This should melt the ice and clear the drain hole....Catriver...post back.
Aug 16, 2006 | Frigidaire FRS26KF5C Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
266 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
