Question about Kodak EasyShare DX6440 Digital Camera
Dx6440 will not power up with new batteries - Kodak EasyShare DX6440 Digital Camera
I purchased a 4 GB SDHC card for my kodak easy share dx6440. The camera keeps rejecting it because 'it is not formatted'. I formated it and it still does not read it. is the DX6440 limited to SD 2GB? ...
The DX6440 uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You are limited to SD cards 2GB and smaller.
Nov 09, 2010 | Kodak EasyShare DX6440 Digital Camera
MY EASYSHARE DX6440 SHUTS DOWN BY ITS SELF OR DOES NOT EVEN COME ON
Make sure that you are using a fully charged battery and of course the recommended battery for your camera such as 2 AA lithium battery or Ni-mh battery. If you already done with all this thing it time to contact Kodak at 1 800 235 6325 ext 12 and send your camera for repair
Feb 04, 2010 | Kodak EasyShare DX6440 Digital Camera
DX6440 won't turn on; doesn't charge beyond first green bar in stand. New battery didn't make a difference. History of lens cover not opening fully.
Went to Kodak's interactive solution page... didn't solve or give information as to why... but stepped me through several "tests" to clarify that camera was still operative through dock power source but that power was not being received through point of battery or recharging and would have to go "in to shop" for repair. I would have preferred to understand what/why it wasn't working properly.
Oct 02, 2009 | Kodak Cameras
Won't go on
Hey ghgyu,
I would first make sure you have the batteries installed correctly. If you are using a camera dock or you have an AC adapter cord I would try removing the batteries and try turning the camera on while connected to the camera dock or plugged into an outlet with the AC adapter cord. If the camera works this way I would then try cleaning the battery contacts with a soft cloth or an eraser. If none of this works I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 09, 2008 | Kodak EasyShare DX6440 Digital Camera
Kodak dx6440 wont power up lens wont and retract
I have the same/similar problem. I could hear the camera attempting to retract the lens. Camera shut down after timeout.
Disassembled camera & found two teeth missing from plastic gear in gearbox attached to lens motor. Don't know yet if part(s) are available.
Camera had light use. Patheticly short life & that Kodak didn't use stronger nylon gears. Bought a barely use Kodak P880 recently, & the autofocus died shortly after. Web search showed others had same failure. I'll never buy another Kodak camera.
Sep 20, 2007 | Kodak EasyShare DX6440 Digital Camera
How to replace battery cover for Kodak Dx6440
We had the same problem dropping the camera, and ordered a pair of new battery covers. I was able to install this by carefully removing the cover screws and slipping the pins into their slots. I am sure you probably got it by now.
This problem was before the one posted about start and then die. The "expert" response posted was worthless. This whole website seems to be a collection of anecdotal semi-worthless stuff.
Perhaps other topics may contain more relevant valuable commentary.
Sep 16, 2007 | Kodak EasyShare DX6440 Digital Camera
No power
Not sure if this is related, but our's won't start-up either, and it seems to indicate that the batteries are weak/dead prematurely. There must be some sort of power level controller that could be the root problem. Our experts can add some useful content to both these threads....
Aug 08, 2007 | Kodak EasyShare DX6440 Digital Camera
Camera lens will not open
Lens motor shot- contact Kodak repair price likely to be well on the way to a new camera
Jul 31, 2007 | Kodak EasyShare DX6440 Digital Camera
Stuck :(
My Kodak DX6440 did the same thing. After sending it to Kodak's third-party repair (as per Kodak), they called to say it was not fix-able. Kodak's response was "No parts available" and offered 10% off list price of a refurbished camera. ...Big sports ...Way to keep customer loyalty If you choose Kodak, the cameras are good but buy them knowing they are a disposable item. BK
Jan 22, 2007 | Kodak EasyShare DX6440 Digital Camera
Kodak DX6440 won't power up using batteries
There's a chance that the drop is irrelevant to your problem. You could try using a small eraser to clean the battery contacts down in the chamber (make sure to dump out any eraser particles) and try a new CRV-3 battery, which because of it's slightly longer body produces a little more pressure on the contacts. If that doesn't work to improve things then your cam might need a repair, your call there. Good luck
May 02, 2006 | Kodak EasyShare DX6440 Digital Camera
Kodak EasyShare DX6440 Digital Camera Logo
50 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
