Question about Mitsubishi CS-40307 40" TV
Black screen I have a 40" mitsubishi old tube TV, I think of the bigger(and heavier) TV's made... I recently moved it, and it looks good when I set it up, but as soon as any of the displays exit the screen, i.e: volume bar, time, channel, a large black box appears only letting you view about a 3 inch border of the actual picture. I know the entire screen does still work as you can see the picture fine again if you change the volume, but that only lasts 3 seconds. Thanks,
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Go to TV menu and locate Close Caption / Tele Textand disable it.
    Champion:
  • 252 Answers
Use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Posted on Jan 26, 2009
I have a Mitsubishi 82" tv. It looks like someone has sprayed black spray paint all over the screen. The picture is moving around fine but the black spraypaint looking material is stationary. What is
This looks like the backlights have failed. These are fluorescent tubes and the tubes may be turning black, much like the ones you see for lighting. I would expect this if it is a few years old but not from a new one.
Jan 16, 2015 | Mitsubishi Televison & Video
1996 mitsubishi 40" tv has a black screen and
no pic at all usiually means the the heater element in the picture tube it self is burned out. Also there could be a problem with the internal power supply that gives electricity to the heater element. These are all thing the cunsumer cant fix. You either need to trust ONLY a certified Mitsubishi TV repair man, or replace the TV.
I know it's not great news, but if this advice helps, please give me a good rating.
Jun 30, 2011 | Mitsubishi CS-40505 TV
Oversized picture problem
Several possibilities, if you use a set top box to get your signal like a cable box or satellite receiver they will have settings that effect picture size. It could be a high voltage problem inside the TV causing an effect called blooming, if that is it you can usually change brightness and or contrast and see the picture get smaller and larger. I don't recall that set having any customer settings that could give that symptom.
Sep 11, 2009 | Mitsubishi CS-40503 TV
Small red dot in center of 53" Hitachi projection tv
hi, not good news it`s probably a burn in on your red crt (picture tube), tv has to have back completely removed, which means top and bottom covers, (carefull with the top cover it`s heavier than u think, has mirror bolted to inside), turn on tv just long enough to light up all 3 crt`s to identify the red one, turn set off & look into red lens,(may need flashlight) if you see any black specks in center of tube it`s burnt and has to be replaced, be advised u will see gnats, ect. inside but your looking for specific speck, if no visible burn mark have tv man come out, otherwise it`s very pricey, hope this helps and not crt, video-tek
Jun 06, 2009 | Hitachi 53UDX10B 53" Rear Projection...
TV has sound but screen is black.
The most common problem with sets was the high voltage transformer which to my knowlege is no longer available. I had a source for good after market transformers but that has even dried up. Sorry for the bad news.
Dec 21, 2008 | Televison & Video
My VS-50609 Big Screen tv is showing only black and white
Maybe your colour setting is wrong or worse your color tube is no good. You will have to change the screen settings (color). If it wont work probably color tube is gone.
Good Luck
Dec 12, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Replacement lenticular screen for vs6041 60 inch mitsh
we recently cracked our lenticular screen on our 73 in mitsubishi i called the manufacturer and they said they no longer make them. so i looked thru websites to see if i could find some one with a 73 in tv or bigger that they were no longer using or didnt work and i found a guy on www.ksl.com that had an 80 inch tv and we went to go pick up screen cut it to my tv size and it worked!!.
Jun 24, 2008 | Televison & Video
Mitsubishi CS-40707 Greenish/Yellowish Display
Yeah, I had mine checked for the same thing. The "blue" - There's only three - red yellow blue- portion of your tube died. Not repairable. Last I checked it costs at least $1,000 for a new 40 inch tube. Good luck. Mine went to the garbage dump!
Feb 25, 2008 | Mitsubishi CS-40707 40" TV
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
