Question about HP Photosmart 5510 Wireless e-All-in-One Inkjet Printer, Copy/Print/Scan
Spring fell off hp photosmart 5510
Springs fell off ink cartridge dont know where they go
5 Suggested Answers
SOURCE: HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Posted on Apr 07, 2008
FixinFax
  • 3085 Answers
SOURCE: where to i install the ink cartridges on a
Pull on the gray handle just above the paper tray to open.
Posted on Oct 12, 2009
  • 5 Answers
SOURCE: x-spring tab broken in ink receptacle (HP officejet 7310)
I have the same problem, I can fix the wire in place, but there is a second problem, the wire poked a small hole through the thin plastic circuit membrain at the back, so even taping the wire in place no longer fixes the problem.
Posted on Jun 14, 2010
vishwa14379
  • 191 Answers
SOURCE: hp photosmart 5510 will NOT print black even with new cartridge. Help!
try changing settings to default
Posted on May 22, 2012
Hp photosmart 5510 is giving ink system error 0xc19a0042
It either telling you your ink is low,or cartridges need a cleaning,which your machine will do that for you.
Nov 17, 2014 | HP Photosmart 5510 Wireless e-All-in-One...
My hp 5510 photosmart printer will not print in black
Make sure you have run a cleaning cycle before spending money replacing anything. Sometimes the print heads will get a little dry and a color or multiple colors will stop printing. Have you replaced the black cartridge recently? Make sure you have pulled all the tape off correctly. There is an air hole that needs to be opened usually under the tape that will prevent the ink from flowing out of the cartridge. Let us know what your results are after checking the cartridge and running a cleaning.
Jul 07, 2014 | Brother HL-2040 Laser Printer
Error message printhead missing HP photosmart 5510
This indicates that your head is not correctly installed.
Clean the contact surface with a tissue paper then try to insert it until it snaps in place. On hp printers the ink cartridge is the print head.
hope it helps
Nov 05, 2011 | HP Officejet 5510 All-In-One Thermal...
HP 2610 AIO Printer - ink carriage broke.
The X-bias spring failure has punctured the ribbon cable in the ink cartridge shuttle. I need a new ink carriage assembly, the part number is C8963-60101. HP does NOT have any more. Where can I get one?
May 11, 2010 | HP Photosmart 2610 All-In-One InkJet...
A spring fell out in my hp psc 2410 photosmart printer and don't know where it goes. now my printer is saying error cartridge jam during printing
i wouldn't even bother trying to repair it, take the printer and the spring to best buy and they will probably fix it for free.
Mar 06, 2010 | HP PSC 2410 All-In-One InkJet Printer
HP 5510 will not print using black cartridge
  • Put a tiny drop of isopropyl alcohol, or bio ethanol on the opening of the printhead (remove cartridge, you will see the opening below the cartridge)
  • Put cartridge back
  • Clean print heads
  • It WILL work again!
Jun 03, 2009 | HP Officejet 5510 All-In-One Thermal...
HP Photosmart, black ink running out too soon.
Not many. Black is also used to make color prints. HP's business relies on selling you ink cartridges, not selling printers.
Dec 27, 2008 | HP Officejet 5510 All-In-One Thermal...
Black cartridge is not being recognized, amber light blinking
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Nov 10, 2008 | HP Officejet 7210 All-In-One InkJet...
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
HP Photosmart 5510 Wireless e-All-in-One Inkjet Printer, Copy/Print/Scan Logo
44 people viewed this question
Seeker5211
Seeker5211
