Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Xml problem i am playing the football manager since the first day it was realesed! the last few days i have a problem!i heard it's common! when i submit my team and it's going to the match it stops and it goes to the desktop and says in a white box: not well formed (invalid token) at line 1 of highlights.xml and then the same for speed and camera! i don't know what to do!!! please explain me what i have to do in details!!!!!please!!!
  • hpapastamkos Jan 26, 2009
    i don't know what to do!!! please explain me what i have to do in details!!!!!please!!!i have done unistall and install again the same!
  • 11,896 Answers
DID YOU FORGET TO change screen resolution to what stated on back of game box?
Also, You have to delete all of your Graphics folder, tick skin cache and then untick always reload skin on confirm.
Are you running the latest Patch mate?
If you have a shortcut on your desktop you can do the following:
* Right-click on the FM shortcut.
* Choose "Properties" from the pop-up menu.
* In the "Target" field, add the --reset_preferences command line option after "fm.exe", so it should look like this:
"C:\Program Files\Sports Interactive\Football Manager 2009\fm.exe" --reset_preferences
* Press OK and then try to run the game as normal, using the shortcut.
You'll want to remove the command after you run the game, as otherwise it will continue to reset your preferences every time you launch.
If you don't have a shortcut you can make one and then perform the instructions on the shortcut you've made.
* If you purchased and installed the game through Steam you should be able to find the fm.exe in the following directory:
C:/Program Files/Steam/SteamApps/Common/Football Manager 2009/
* If you purchased and installed the game from a boxed DVD copy you should be able to find the fm.exe in the following directory:
C:/Program Files/Sports Interactive/Football Manager 2009/"
Posted on Jan 26, 2009
  • 916 Answers
Please download xp service pack 3 it should solve your problem. It can be found here: Click Here
    President:
  • Microsoft Master
  • 1,314 Answers
Before doing that, do a system restore and restore your computer back to a date that it was working. Go to start, programs, accessories, system tools, system restore, and follow the onscreen prompts.
  • Microsoft Master
  • 13,433 Answers
Hi, a file is corrupt.
Uninstall the game, fully, from add or remove programs.
start -> control panel -> add or remove programs or uninstall programs
find the program and uninstall.
Get the cd, and install the game again. The problem should be solved, if not let me know.
Xml parsing error
I would recommend to try the following procedure:
C: -> Users -> -> AppData -> Roaming -> Sports Interactive -> Football Manager 2011 -> Settings (Windows 7 / Vista) or C: -> Documents and Settings -> -> Application Data -> Sports Interactive -> Football Manager 2011 -> Settings (XP)
You should locate the "Settings" folder - delete it. However make a copy of it, because I must warn you, that you could potentialy lose all your saved games. However, it should get rid of the XML parsing error.
Aug 20, 2011 | Sega Football Manager 2011
My footbll manager 10 will not play, a bar comes up saying' not well formed (invalid token) at line 1 of default.xml
Try reinstalling it. to reinstall it, go to Add or Remove programs. Then go to Add Programs, then click on CD or floppy(if you have a floppy drive.If you don't have a floppy drive,then it will say CD and something else).If this still comes up, then i don't know.
Hope this works!
May 18, 2010 | Sega Football Manager for Windows
Football Manager 2010 has an error occuring ''not well formed error in profile line 2 xml? Can you help
Hi! If this error comes up on the game, try reinstalling it by going to Add or Remove Programs. Then click on Add Programs. Then click on the first tab in there. If this still comes up, then i'm out of solutions.
Hope this helps!
May 15, 2010 | Sega Football Manager for Windows
Try Reinstalling. To do this, go to Add or Remove programs. then go to Add programs. then click on the first tab in the new screen. If this doesn't work the I don't know.
Hope this helps!
Mar 28, 2010 | Sega Football Manager for Windows
Hoping someone can help - I was playing Football manager 2009 on my laptop but the battery died. After charging it again when i tried to play it again an error came up saying 'xml parsing error - not well...
You could go into your Add/Remove programs and select the program for removal/repair. if it comes with the repair feature, you'll probably be taken throyugh a series of options, otherwise uninstalling it and reinstalling it all over again would be the last resort.
Jun 21, 2009 | Microsoft Windows XP Professional With...
Football manager crashes when playing a match
Close the game.
Go to C:\Documents and Settings\<Your Username>\Application Data\Sports Interactive\Football Manager 2009\settings\
Delete all folders (NOT the settings one, but the sub-folders)
If problem persists, please copy error exactly.
May 06, 2009 | Microsoft Windows XP Professional With...
Parcing error
Follow this link for instructions on how to fix this problem.
http://football-manager-blog.blogspot.com/2008/11/fm-09-football-manager-2009-xml-parsing.html
Please rate my response
Apr 20, 2009 | Video Game Consoles & Games
My Football manager 2009 disc won't load up
Try to look for patches and updates of the program, ormaybe your drivers are old, or not compatible at 100%.
Try thease.
Feb 22, 2009 | Microsoft Windows XP Professional With...
Football Manager 09 has stopped running
on desktop icon fm09 click on properties and then in target wrote this: (only Bold) fm.exe" --reset_preferences
before this two minuses you MUST press Space.
i hope it will be usefull
Feb 03, 2009 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
