Question about Water Heaters
Water heater is not heating water up
I ignited the pilot and it still doesn't warm up water
  • 1 more comment
  • FRANK BRAINARD Feb 01, 2009
    PILOT GOES OUT-RELIGHT BURNER COMES ON FIRES UP , 10 MINUTES LATER THE FIRE/PILOT IS OUT
    water heater pilot goes out, relight-fires up goes out flames out 10 minutes later
  • Dale Koehn
    Dale Koehn May 11, 2010
    is he main burner lighting off after pilot ignition ? did you turn the knob to the on position from pilot ? if the burner does light, can you see if the flame is sharp and strong or kinda just floating around in the burner camber ? any answers to these would be most helpful !
Every part has been replaced by new units except the tank and the water do not heat up the water. The water is hot 3 inches on the bottom and three hour later the water is still cold on the top of the tank.
The ingnitor is still lite and the flame is still going but I dont get hot water. The Gas Company assured me of no leaks and ever part was in place. Whats the problem?
Posted on Feb 02, 2009
  • 2712 Answers
SOURCE: Electric Water Heater Problem
When an electric water heater fails to heat water, either the power to the water heater has been interrupted or there is a problem with the controls or the heating elements. 1) Be sure electricity is being delivered to the appliance. Check the main switch on the water heater and the circuit breaker (or fuse) that serves the water heater. 2) Check the high-temperature cutoff in the water heater. Open the panel, and push the reset button. 3) If these steps don’t solve the problem, call an appliance repairperson.
Posted on Aug 27, 2008
muttandjeff
  • 359 Answers
SOURCE: this is a new whirlpool hot water heater.pilot
LP OR NAT GAS , IF IT IS LP CHECK GAS PRESSURE @ TANK AND MAKE SURE NOT TO HIGH , IF NAT STILL COULD BE THE PROBLEM HAVE THE GAS COMPANY CK PRESSURE
Posted on Feb 23, 2009
  • 351 Answers
SOURCE: new gas water heater pilot light will not ignite
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Posted on May 03, 2010
motor1258
  • 6674 Answers
SOURCE: the electronic ignition on a gas water heater will
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Posted on Jul 20, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: hi we have a Ruud
Sorry to read about your problem, I hope this helps you out.
you have a defective gas control, thats the big metal unit, with the dial on it, it needs to be replaced, no repairs can be made to it.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Pilot light ignites, but does not stay on when I release and want to push to the right position to warm the water
Most gas heaters have a heat detector set in line with the pilot flame. Sometimes this can become covered is soot or carbon. Clean with sand paper 120 grit or less
Apr 11, 2015 | Water Water Heaters
Pilot light is working but cant get heating or hot water
If your pilot is lit, and you have valve turned from pilot to ON, and thermostat is up on warm or hot, and you still don't have main burner on, then you have bad gas valve (the square thing with temperature and on/off/pilot). These unscrew from water heater and can be replaced, but keep in mind that they go directly into tank, so shut off water and drain unit first!
Jan 06, 2015 | Water Water Heaters
My Power went out and was out for 1 1/2 days. It must have affected my water heater as well because my water is constantly cold will not warm up. i notice the water heater ignitor isn't on and after...
Could be bad regulator valve. Make sure you follow the lighting directions to the TEE. But if it will not light at all in pilot mode, its most likelt a the regulator valve.
Oct 16, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Cannot find pilot light on my bosch GWH635ESL, help!
Call Bosch
Gas Products Technical Support: 800-642-3111
That model number is only shown at one website, and that model number is not shown at Bosch.
Open following link for Bosch:
http://www.boschwaterheater.com/BoschHotWatercomHome/GasProducts/tabid/331/Default.aspx
Search of Bosch for that model number shows no result.
Some water heaters do not have a pilot light. Instead they use hot surface igniter rod that glows red hot
The igniter rod ignites the gas after solenoid valve opens and gas flows to combustion chamber.
The igniter rod and heat sensor have to be operational, and have to be positioned correctly for ignition to take place.
If igniter rod is not working, or if heat sensor does not detect flame, then gas solenoid valve shuts down and water heater does not heat water.
Sep 03, 2011 | Bosch Water Heaters AquaStar - Tankless...
Atwood Water Heater G6A-7E, electronic ignition. Should after the water is heated a small flame is still present at the orifice. It is like a pilot flame. I thought that the electronic ignition was to...
You are correct, there should be no flame after it shuts off. Pull the + wire off at contacts as well and see if flame remains, if it does, the gas valve is faulty (leaking by) and should be replaced.
Jul 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
Hot water heater does not light
burner and pilot assebly and orifaces need to be cleaned
Sep 16, 2009 | Fasco Bradford White Water Hot Heater...
My hot water tanks pilot light turns off after I have relit it. It stayed on while heating the water in the tank and once it stopped heating the pilot light went out again. What would be causing my...
are you holding button down long enough for thermal coupler to warm up? after pilot lights up, don't immediately let go of button for about 15 to 20 seconds then let go and pilot should stay on. If not, you may need a new thermal coupler for that water heater
Jul 03, 2009 | Water Heaters
Water Heaters Logo
198 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
