Question about Kenmore Washing Machines
Drum wont spin in washing mode. it only works for rinsing and dry spinning. sharp ES-M38 washing machine
    Sergeant:
  • 291 Answers
Because i know nothing about Sharp washers could you tell me if it's front loading or top loading? Is it less than 6 years old? Does it give any error codes? Thanks.
Posted on Jan 20, 2013
SOURCE: F&P smart drive 601 washing machine will not advance from wash mode
on those washers the waste water pump will get hair and **** wrapped around the shaft behind the pump fins. pull the washer forward and tip it back so you have access to under the front. on the right fron you will see a little pump. unplug the power clip and the ground wire. there will be a plastic tab you must bend a little so that you can twist the whole motor, not just the fin on the back, counter clockwise and remove. if you have water in the machine it will come pouring out. your machine will not rinse or spin if the waste water pump does not pump out enough water in its alloted time. when you have the motor out unscrew the pump fin cup thing and pull all the stuff off the pump. good luck.
Posted on Oct 19, 2008
barkencoa
  • 3463 Answers
SOURCE: Machine wont go into spin cycle
The pump fiter is probably blocked.
Remove lower rear panel of washer.
Locate, and remove large black hose on bottom of tub.
Remove plastic filter inside, and clean.
Refit filter and hose.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
Macmarkus
  • 2605 Answers
SOURCE: GE WSSH300 front load washing
Welcome to FixYa
It sounds like (based on your initial description) the unit is detecting an incomplete drain or an unlocked door, hence the control will not initiate a hi-speed spin. Since you've checked the drain already you can likely rule the incomplete drain a non-factor.
I know most folks will rule out the lock initially because the unit does indeed "lock", however, the lock on these machines are a two part device, a set of contacts to lock and a secondary contact to activate hi-speed spin, i.e.
If it does indeed drain fine, then here's the next place I'd direct you to investigate.
**Unplug the unit from the wall first...safety first**
It will require you to visually inspect the control board, thus needing to remove the top panel by way of taking out the screws at the back and sliding the panel back and up.
What to look for specifically is the wires with the green connector fastened to the board securely...I've seen a few vibrate loose thus preventing the unit from spinning, i.e.
If loose push it all the way in until it cannot be pulled out with a slight tug ( there are clasp's on the connector but I suspect sometimes they aren't secure when leaving the factory...just my suspicion )
If these things can be ruled out, then it is quite likely the door switch, so here's how to change/access the latch assembly...
**The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, ASIDE FROM PUMPS BEING OBSTRUCTED.**
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **UNPLUG THE WASHER FROM THE WALL OR TURN OFF THE BREAKER.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Mar 02, 2011
Testimonial: "thanks we tried everything else and am now ordering a door lock"
My beko wmb61431s will work in spin or rinse mode
check the clutch, the belt, the motor coupler, the door switch,
Feb 25, 2015 | Beko Washing Machines
Sharp washing machine,ES-AG950 hangs during the spin cysle.
Sounds like its tripping the drum vibration sensor or a temp limit sensor on your motor.
Apr 09, 2013 | Washing Machines
Telmann TEL6TL washing machine doesnt spinn properly, brake motor not activated
replace whole mechanism if cheeper than replacing unit and dont want to pay a pro
Jun 19, 2012 | Washing Machines
Have a Kenmore 20902 top loading washer. Does aggitate in wash cycle, but wont spin in rinse. With drum empty, it will spin. Removed cloths, rung dry by hand and returned to drum. Still would not spin, but...
Your drum is in a sense sitting on a barring , it sounds like your barring is going out. Works with no weight, and if helping as you said. Normally means barring is worn out and can not handle any weight.
May 08, 2011 | Kenmore 22422 Top Load Washer
My Sharp ES-A50S washing machine won't spin dry. the alarm warning that the lid is open always sounds off even though I closed it already. what should I do????
ok your problem is due to some problem with lid sometimes a heavy wait on lid of dry drum makes it settings wrong alignment is not correct plz call the mechanic there it will fix
Sep 14, 2009 | Washing Machines
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
LG wft7014pp wont drain rinse nor spin
do you have a drip-dry function...as this cancels the spin cycle unless you select it yourself
Sep 21, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
277 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
