The LED light was flashing (the remote was already programmed someone else programmed it for me) so I took out the battery and now I need to reprogram it. The instructions are in very tiny print and I
  • 496 Answers
First you need to find the program button or input button. Almost all universal remotes are the same process for programing.Aim the remote at the tv and push the tv device button once then use the program or input button push and hold till the light blinks twice or stays on then put in your 3 or 4 digit code and press enter.
Posted on Jan 20, 2013
SOURCE: philips universal remote control cl034
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Try this website it really works. I just tried it today and I am sooo happy.
Posted on Feb 22, 2008
SOURCE: programming my remote
http://66.77.167.109/rcaaccessories/BrandCode.do
go here for your codes to any rca remote
Posted on Mar 22, 2009
SOURCE: need to reprogram universal GE remote
below is the online manual:
http://www.fixya.com/support/p237065-ge_rm24930_remote_control/manual-11900
Posted on Jul 13, 2009
nuclearfish
  • 4 Answers
SOURCE: need to reprogram sony RMT-V501E remote for a Daewoo television
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
Posted on Oct 17, 2009
How do I replace the IR sensor?
If you took the batteries out of your remotes to change them, they possibly lost their programming and need to be reprogrammed. I drop my controller often and have to reprogram it. All of the lights light up but the TV appears dead. Either find your control programming guide or look it up on the internet how to reprogram your remote.
Jan 06, 2015 | LG 42LG30 42 in. LCD HDTV
Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES.
GOOD LUCK
STEVE
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Reprogram astrostart j5f tx2000
Get under the dash or where the unit is located.
You will see 8 or 9 dip switches on the unit with an LED beside them.
Turn switch 1 and 8 on.
Press and release the brake. (LED will flash)
Press and hold start button on remote. (LED will flash and parklights will flash once.
Turn switch 1 and 8 to off.
Press and release the brake (LED will flash once)
In future would be a good idea to supply vehicle details etc as can sometimes be a known condition , that saves time looking it up , good luck
Nov 18, 2014 | Cars & Trucks
Im trying to reprogram my remote and I know the code. But while I am holding down tv and I press 0 (the first number), the light flashes before I finish the code. I tried starting with other numbers,...
Press and hold the component key (TV, SAT•CBL, DVD•VCR, DVR•AUX) you wish to program. The LED turns on and remains on.
Keep holding down the component key. If you release the component key any time during the Direct
Code Entry procedure, the LED blinks four times, and the process is exited. The last programmed code under the component key is retained
get the full manual for free including all codes HERE
Oct 07, 2010 | RCA RCR-4258 Remote Control
Just replaced the battery and it doesn't work...any advise?
If the battery didn't fix it is probably has just quit working.
Jun 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Honda civic 96 keyless remote not working after new battery
Sounds like you may need to hit the dealership on that issue. Call them and talk to parts and let them know what you have done already.
Mar 10, 2009 | 1996 Honda Civic
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Door close with wireless remote entry but will not open
It sounds like this remote has lost its program! you will have to reprogram it!I hope this helps ya!
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Nov 22, 2008 | Akai LCT3215/26 32 in. LCD Television
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
