Question about Canon Digital Copier/Printer
Paper jam in canon digital copier ir2318l but no paper inside
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
digitalhubz
  • 109 Answers
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
SOURCE: Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Posted on Jan 09, 2011
canontech
  • 1219 Answers
SOURCE: Canon iR2318L digital copier/printer is showing
hello,
you need to change the fixing film in fixing unit! The fixing film is worn out!
There is no reset for these type of error! Call service!
Hope that helps!
Posted on Jun 18, 2011
MY IR2318L CANON COPIER IS FAILING TO PICK PAPERS FROM TRAY, WHAT COULD BE THE PROBLEM?
pick up roller after fifty thousand required replacement
check and replaced
Jan 18, 2015 | Canon Office Equipment & Supplies
I M facing paper jam error problem after replacing sleev of fuser. Make Canon iR2318L.
is it showing some error code.open the fuser unit and then check the pressure roller bushes.sometimes they move from there place causing paper jams.do check whether u have applied right amount of grease to the fixing film and do check whether the white sensor of the film is in right position.u have to just fit all the parts rightly .it has something to do with these said things
Aug 15, 2011 | Canon imageRUNNER 2200
I want to print free size paper in the stak bypass.
Set the bypass guides for the largest size paper in the document. Bypass feeders are dumb, they don't care what size the paper is.
Mar 14, 2010 | Canon Office Equipment & Supplies
INVISIBLE PAPER JAM!!!
sometimes invisible paper jams are cause of teared piece of paper that was left over inside the paper path please check again if there are piece of paper left inside and paper detection switches are ok.
Dec 19, 2009 | Canon CLC 1150 Color Copier
Canon pixma mp810 keeps jamming ....the paper won't feed through the back or the front
Go to this link. In the search window in the center of the screen, type "paper jam" and click on the search button. Then select "paper is jammed inside the printer" and "removing paper jams". You will see an illustrated guide to checking all areas where paper may be jammed inside your printer.
Aug 21, 2009 | Canon Office Equipment & Supplies
Paper jam in canon Imageclass D861 copy machine
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon ir 2016 digital copier
Are you living in the USA? The size A4 is the Europe size of paper to our letter size... You can try to take the paper tray out and look inside, for any paper jammed in the back of the paper tray area.
Mar 19, 2009 | Canon Office Equipment & Supplies
Paper jam flasher
Henry, try blowing it all out with compressed air to clear jamb.
Nov 27, 2008 | Canon NP 7130 Black and White Copier
Canon Digital Copier/Printer Logo
35 people viewed this question
old marine
old marine
