Question about HP Compaq nx6110 PC Laptop
Diagram usb - HP Compaq nx6110 PC Laptop
    Sergeant:
    Champion:
  • HP Expert
  • 427 Answers
Ask HP for it. They will provide it.
Posted on Apr 17, 2013
Front usb wireing diagram
ECS P4s5a info here :
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=37&CategoryID=1&MenuID=18&LanID=0
go to the above link and click on download and manual. Look near the bottom of the page for the user manual and click on the closest country to you to start the download in PDF format.
The front pin diagram is on pages #14-15
and the USB pin diagram is on pages #28-29
you will need adobe reader or similar to be able to read the pdf files
Jan 10, 2013 | ECS P4s5a Socket 478 Motherboard
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
Diagram fr audio 2 usb cable means data &charging both in one fr shuffle apple ipod
Yes, the charging is done via the 5 volts supplied on the USB cable.
Google this: ipod shuffle usb cable diagram
That will bring up the diagram!
Apr 23, 2010 | Music
Connection diagram plug the USB ports to the EliteGroup P4S5A/DX+
Here is a link to the manual for your motherboard. It should show you how to connect your usb cables.
Hope this helps.
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=39&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Nov 09, 2009 | EliteGroup P4S5A/DX Motherboard
Circuit diagram for charger for Black & Decker KC96 cordless drill
You can contact a Dewalt Service Center to see if they have the diagram. Black and Decker is Dewalts lower priced line. A quick search on their website did not reveal anything. They may not have the diagram. As far as I know there are no parts available for the chargers so you may have a hard time locating the diagram. Try giving Dewalt a call.
Sep 11, 2009 | Black & Decker Drills
Furuno gps wiring diagram for usb
Hello!
I have the connection diagram for the GPS unit below.  It should be simple to wire up.  You will need a USB to RS-232 converter, which is available in a number of computer shops/Radio Shack.
Hope this helps you out,
Jan 06, 2009 | Furuno GP31 GPS Receiver
Searching for a wiring diagram for my E machine....
Industry Standard Architecture exists here.
The pin arrangements for USB are standard, some usb headers are attached to the boards in the opposite direction but the pin arrangement is the same.
USB headers consist of 9 pins, arranged as 4 pins and one missing, and 5 pins like this:
x x x x o
x x x x x
these are marked as:
vcc1 usb 0- usb 0+ n/c
vcc2 usb 1- usb 2+ n/c
colours are:
red, white green black
Note: some motherboards have these connectors back to front but the connection sare as per the diagram
the audio header is arranged as follows:
X X X O X
X X X X X
top row = gnd, vcc5, mic2,n/c line
bottom row = mic1,mic r, line out,front spk r, lin out L
The cable colours may differ but the preformed plug will only fit in one place /direction
Oct 27, 2008 | E-Machines (308714) Motherboard
HP Compaq nx6110 PC Laptop Logo
14 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
