Question about Kenmore Elite 30 In. Electric Self-clean Single Wall Oven Convection Stainless
Kenmore wall oven will not heat past 250 degrees
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 12 Answers
Check your main board you will find loose connection
Posted on Jan 20, 2013
Noggin
  • 944 Answers
SOURCE: Electric Wall Oven
First thing to do would be to check (or call an electrician) to see if the electricity supply is still adequate. occasionally corrosion or rodents or similar can effect the voltage to the oven. usually with this problem if it was the oven itself it could be the thermocouple - the device that tells the oven what temperature it is at - usually a small metal tube (sometimes with a bulbous part along it) that will stick through a hole in the oven wall somewhere (often near the top). If you can identify this thermocouple then just see if it has been somehow bent or pushed closer to where the heat enters the oven - sometimes these can be gently bent back and will usually have a clip to hold it in place. Another route would be to contact their service reps direct on: http://www.sears.com/sr/misc/sears/custserv/custserv_index.jsp?BV_UseBVCookie=Yes&vertical=SEARS Hope it helps :)
Posted on Feb 27, 2007
  • 109 Answers
SOURCE: oven doesn't heat up enough
More than likely the oven requires a new thermostat, but would recommend an Appliance Repairer to confirm this solution.
Posted on Jun 16, 2009
heatman101
  • 43501 Answers
SOURCE: kenmore electric oven doesn't heat
The baking element is the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 12, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a Kenmore Gas
Hi
It is not the bake element....The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1120 ohms then it should be replaced however, if it reads between 1080-1120 ohm then check the control and door switch and replace the part that is bad. Hope this helps...
Daniel
Posted on Feb 04, 2011
Daniel S
  • 4323 Answers
SOURCE: Kenmore wall oven JGRP17 911.30465
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 13, 2011
My Kenmore oven will not heat above 250 degrees and beeps I think F2
Oven temperature sensor shorted. Replace with a new part.
Dec 03, 2015 | Kenmore Ovens
I have an electric kenmore model 362 oven/stove trouble.
Are you sure that there is not a buton on it that says degrees Celcuis of Farenheit. It happened to me a few years ago. If there is such a button try pushing it to see if it will go back to normal.
Feb 28, 2013 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
Duke Convection Oven won't heat past 250 degrees
Why should the cooker burn that hot, when you can cook most things at a max 220Celsius
Sep 27, 2009 | Duke 59-E4Z Electric Single Oven
GE wall oven
Hi Den3,
Are you sure that you have not inadvertently switched to the Celsius temperature mode? A temperature of 282 degrees C corresponds to 540 degrees F.
I doubt that it is the heating element. They either fail by short circuiting or by opening up completely.
Regards,
Powerman
Sep 15, 2008 | Ovens
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Electric Wall Oven
Feb 27, 2007 | Kenmore 30169 Electric Single Oven
Kenmore Elite 30 In. Electric Self-clean Single Wall Oven Convection Stainless Logo
323 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
