Question about Olympus EVOLT E-500 Digital Camera
Help The hotshoot on my camera is loose. When the flash is attached, somtimes it doesn't make a connection to the camera. This problems stops the camera from flashing because the sensors are not connecting.
    Genius:
  • 2,985 Answers
An extern flach should have a 'screw' down whell on its shoe to firm us the connection does this one not have it?
Posted on Aug 20, 2007
SOURCE:
SB 600 has stopped firing batteries are good
flash bulb could be burnt out...if it doesn't fire when when you push test, that's my guess as to the problem. Another possibility (although unlikely) is a loose connection in the flash.
Oct 23, 2009 | Nikon Speedlight SB-600 TTL Flash
Olympus e510 hot-shoe doesn't respond...
Have you tried cleaning the hot shoe contact? If the contact is dirty it may not communicate with the camera. The "contact" Its the metal "circle" in the middle of the hot shoe. Using a pencil eraser, rub the contact gently until you create eraser crumbs, then gently rub the "circle" with a soft cloth. See if this fixes it.
Mar 11, 2009 | Olympus Safe Hot Shoe to PC Sync Flash...
AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Feb 20, 2009 | Pentax *ist DL Digital Camera
Intermitant various washer problems
Intermittment cycling is usually caused by either a loose connection or a timer issue. If all wiring is plugged in tight than you should replace the timer.
Jan 10, 2009 | Washing Machines
Internal Flash not working-Canon Eos 40D
I've had this happen to me too and I've been researching about it. Aparantly it happens because the camera still think the external flash is attached. If you go into the menu and under flash control, try ot enter the settings for built in flash. If this is the problem it will tell you here that the external flash is still attached. From what I have read to far, I'm not sure how to fix it. I would reccomend taking it in somehwere. I dont htink its a hard problem to fix.
Dec 06, 2008 | Canon EOS 40D Digital Camera
Flash off
Remove the camera case (about 10 screws) and expose the circuit board that is attached to the camera chassis. Look at top button board (shutter and video buttons). This is also the flash board. The capacitor is attached to the board. The flash board has a serial cable and two wires that connect to the main circuit board. Severing one of the wires will stop the flash from working. After re-assembling the camera, the camera will not take pictures with any of the flash settings. You will see a constant charging flash message every time the shutter button is pressed. Turn off the flash setting on the camera for your camera to operate.
Nov 08, 2008 | HP Photosmart M425 Digital Camera
Flashing
well you can tap the convergence board and the crt boards see if you can find a loose connection, however be careful there is high voltage
Feb 01, 2008 | JVC AV-48WP30 48" Rear Projection...
K100D flash doesn´t work
My camera with the dodgy flash is holidaying in Japan as they sent it to be fixed - not sure how old your camera is but I am trying to see if this is an issue that occurs with the camera model.... given that there are only two of us to date I am thinking that we may have just struck the jackpot :(
Dec 27, 2007 | Pentax K100D Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
18 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
