Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Fax not working correctly
Faxes not being received legibly;only appearing as black lines on plain white sheet or nothing at all. Fax not giving any indication to change inks (recently done) or that anything is amiss. Telephone working.1471 recall is giving tel no of last fax sent. ?? what can I do I've been here forever and cant recall this before!! Is the fax just worn out!! ??
Regards
    Genius:
  • 2,120 Answers
It sounds like you are out of ink.
Posted on Jan 27, 2009
When I send faxes the person receiving the fax is complaining that there is a solid black line appearing on the fax
hi there
it seems like there is some dirt or correction fluid on the scanner glass ,flip open the cover where the documents feed in you will see a glass ,clean this glass with a damp soft cloth this should solve the problem
Nov 19, 2009 | Brother FAX-2920 Plain Paper Laser
Every time I fax or copy a perfect sheet of paper both the fax received and the copy have a 2 inch wide solid black line on the right. How do I fix the machine?
Have you tried replacing the ribbon cartridge? If that doesn't resolve the problem, then there is a fault with the thermal imaging head. You did say both Recieved faxes and copies, correct? If faxes you send out are clear, then the above mentioned would be correct. Let me know, please.
Oct 12, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
When faxing out-2 large black horizontal lines appear on page
Bad scanner block, sorry. Very expensive if you can find one.
Mar 11, 2009 | HP 1040 Plain Paper Inkjet Fax
Faxjet 525 will not send faxes
it is never getting a dial-tone. Phone line should be plugged into the LINE port.
Jan 28, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Black line through sent faxes
Open up the document feeder and clean the scanner glass.
Jan 05, 2009 | Brother IntelliFAX 885MC Plain Paper...
BLACK VERTICLE LINE IN FAXES SENT, NOT WHEN RECEIVED?
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Will not receive Faxes
The first thing you can try is replacing the phone line between the wall and the fax machine.
Sep 15, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Lines Through Faxes
If WHITE LINE(S) appears clean the scanning unit...if BLACK LINE(S) clean the thermal unit.
Jan 28, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Problem with sent faxes
CIS SCANNER SEEMS TO BE BAD TRY CIS TRAINING FUNCTION IN THE MAINTENANCE MODE AND DO CIS TRAINING USING A PLAIN WHITE SHEET/(FUNCTION *2864 , USE 55 CODE TO DO THE CIS TRAINING) OTHERWISE REOPLACE CIS SCANNER. HAPPY FAXING OMNIPRESENT
Sep 17, 2007 | Brother IntelliFAX 770 Plain Paper Thermal...
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
