Question about Philips PD9016/37 9-inch Portable LCD Dual DVD player
Pd9016/37 region code fix - Philips PD9016/37 9-inch Portable LCD Dual DVD player
Fix BD-E8500A region free
Try these WEB sites for region free code for your player.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Feb 18, 2013 | Televison & Video
Tip
LG LH-D6235 DVD Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Televison & Video
Tip
LG LH-D6235 Region Free Fix
Follow these steps:
I hope that helps.
on Jul 14, 2010 | Audio Players & Recorders
NETFLIX DVD will not play ...
sounds like a region code block on your dvd player this is a risk unlocking region codes for player search internet explore region code for your model follow directions this is a use at own risk code
your dvd is region coded and your dvd player combo is region coded which code i dont know if live in united states the code for this region is one
May 17, 2008 | Sansui VRDVD4005 DVD Player/VCR
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
Invlaid region code
Sounds like you are trying to play a DVD of a different region to that of the player.
Worldwide region codes, sumarised:
1 - US / Canada
2 - Europe
3 - Asia
4 - Australia
5 - Africa
6 - China
You can change the region code of the DVDR520H to any region or use region 0, which makes the unit multi-region to play DVDs from any region.
  1. Go into the main menu
  2. Highlight the exit button
  3. Type 2960
    This should give you access to a hidden menu form where you can change the region code.
Feb 20, 2008 | Philips DVDR520H DVD Player/HDD
Programmed for region 2....Need to change to 1
Q: What is Regional Coding enhancement(RCE)?
A: It's a digital enhancement added to some Warner Bros and Columbia DVDs to stop region 1 (R1) DVDs from playing on Region-free DVD players.
Q: What's the difference between Region Coding and RCE?
A: Regional Coding enhancement(RCE) is an additional layer of protection which some studios have placed on select REGION 1 DVDs to prevent them from playing on region-free or multi-region players. Region Coding is a part of the DVD spec which divides the world into 8 regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Basically, DVDs released in each region will typically only play on players sold in that region. IE a DVD released in the UK *Region 2* would not play on a player sold in the us *Region 1*. You can tell what Region a DVD is coded for by looking at the back of the box for a Globe with a number on it. The number correlates to the region list above. If a DVD is listed as 'Region 0' it means that it isn't coded for any region and should play on ALL regions players.
Dec 14, 2007 | Philips 30DV693R 30 in. TV/DVD Combo
Philips DVP3144 Region Change
The fix on the DVP3120 was as follows. I don't know if this works on 3144 - would like to know.
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Nov 30, 2007 | Televison & Video
Region code
I assume you are referring to the DVD drive region code in your Toshiba laptop.
1. Determine the exact make and model of the drive.
2. Check the mfr's. website for reset instructions.
3. Google - DVD REGION UNLOCK CODE. You will find lots of help there.
Good luck
Oct 12, 2007 | Computers & Internet
Philips PD9016/37 9-inch Portable LCD Dual DVD player Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
