Question about Epson Stylus Photo 1280 InkJet Printer
  • 2,120 Answers
Out of ink.
Posted on Jan 27, 2009
Is my 2005 qiangiang gmi 108 a 2 stroke or a 4 stroke
Hi, David engine design is very easy to identify:
1. Two strokes red line around 12,000-16,000 RPM.
2. A reed valve is in between the carburetor and cylinder head.
3. The exhaust has an expansion chamber.
4. The muffler has a small diameter tail pipe.
5. The exhaust has a high pitched Bap Bap sound.
6. Small scooters and small dirt bikes are generally 2 Stroke.
7. Older models had adjustable throttle actuated oil injection.
8. Older models had a premix ratio of 2 stroke oil and gas.
1. Four strokes red line around 6,000-8,000 RPM.
2. Four strokes have camshafts and valves.
3. Mufflers have large diameter outlets.
4. The exhaust has low pitch deep rumble sound.
5. 350cc and larger engines are usually 4 strokes.
6. Four strokes have separate oil tanks that feed an oil pump.
For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
2005 GMI Motor Sports GMI 108 Scooters
Qianjiang Scooter Parts Racing Planet USA
Full size Scooter Parts
Aug 02, 2017 | Motorcycles
After removing piston and crank shaft in a stihl series 100 motor how do I reset the timing
2 strokes are permanently set
4 strokes are set at TDC with marks lining up
4 strokes with flywheel coils ( same as 2 strokes) are permanently set
Sep 27, 2016 | Garden
I replaced my whole distributer in my 1992 2.8 liter v-6 s-10 but my son washed off the alignment marks, so I was wanderind how i can time it? please help!!!
If you know the engine's number one cylinder location, you need to put it at TDC of the compression stroke, then you lower the distributor in so that the rotor ends up pointing to the #1 spark plug wire tower on the distributor cap. As you drop it down, the gear on the dist. shaft will mesh with another gear and turn slightly. You want it ending up pointing directly to #1. Get it seated, then you can start the engine and set the timing according to specs with a timing light.
To find TDC of the compression stroke (as opposed to TDC of the exhaust stroke), pull the #1 spark plug out. Put a socket and wrench on the crankshaft pulley and turn it in its normal direction (clockwise), with your finger over the spark plug hole. As the number one piston is rising on its compression stroke, you can feel the pressure build up under your finger. You won't feel any pressure as the piston rises on the exhaust stroke, only on the compression stroke. So when you feel pressure, you know the piston is rising on its compression stroke, and you can turn the crank on around until the piston is at top of its travel-the notch on the crank pulley will now line up with the zero degrees mark on the pointer scale beside the pulley. There, TDC of compression stroke. Now drop in the distributor so the rotor tip lines up with the #1 spark plug tower on the dist. cap.
Sep 29, 2014 | Cars & Trucks
What speed,dudy,volts be at for shading and lineing
depends on the work. 12v or so with a well tuned machine and a fast stroke of the hand along with good washing skills will produce really smooth shading. The bugpin rounded shader mags are also pretty legit. Lining should be 6-8v depending on your tuning. maybe higher if you line better with fast strokes. be careful though. high voltage comes with high heat if youre not tuned right. the stroke depth is also really important. with a liner my stroke is around 3.8mm while my shader is set at almost 5mm which is deep for some artists but i like to see the needle since i only use 11 diamond tips for lining if it were a tight fitting round tip i wouldn't really need to see the needle as much. so different strokes for different folks. Remember though, Darker is DEEPER and lighter is shallow. but never go too deep. no one likes a blow out. -Professional tattoo artist- Brian @ Foxy Tattoos, Raleigh NC
Feb 04, 2012 | ART Cast Iron Coil Tattoo Machine Liner &...
Fuel mix for 25cc trimmer
For two stroke engines of this capacity the ratio of fuel to two stroke oil is (25:1) 25 fuel to 1 (two stroke) oil. Eg 200 ml of two stroke oil to 5 litres of fuel.
Jan 27, 2012 | Craftsman 25cc Gas Line Trimmer
Webpage error details
100% working IDM fake key block problem
Mar 16, 2010 | Microsoft Internet Explorer 8
What are the factory settings for the l & h needle valves on the 25cc carb?
usually 1 1/2 turns from snug in will be right. this is true on most all 2 stroke engines and 4 stroke that use a diapraham type carb
Jul 07, 2009 | Craftsman 25cc Gas Line Trimmer
Need help setting the timing
The main timing mark on the pulley usually runs all the way across it. Connect timing light to #1 plug wire...You don"t need to know when on compression stroke! If you need to know for another reason, remove the valve cover and watch rockers on #1 cylinder. Compression stroke happens right after #1 intake valve closes. (both rockers "at rest" at top of stroke.)
Apr 20, 2009 | Pontiac Firebird Cars & Trucks
Need to set timing marks on a 1986 plymouth reliant
To save some time I'll guess and say it's the SOHC.
1). Make sure the #1 piston is on the compression stroke @ Top Dead Center. You can find the compression stroke by pulling the #1 spark plug and putting your finger over the hole, while a friend bumps the engine. When you feel air come out of the plug hole, your on the compression stroke. Then point the rotor to #1 on the cap, by turning the crankshaft by hand. Then do the timing marks.........
2). The camshaft gear: There should be four large holes and one small hole, the small hole should face perfectly straight up. You can use 2 of the larger holes, one on the left and one on the right from the camshaft attaching bolt, to help line it up correctly. By looking through them, horizontally line them up with the head.
3). The crankshaft gear and the intermediate shaft gear should have a dimple on one of their teeth. Face them to each other.
4). Make sure nothing moves, when installing the belt.
5). Fire it up, before you put everything back together. When it fires, let it run for about 30 seconds to let the belt align itself. Then check all your marks again, to make sure nothing moved.
6). Put it back together.
7). I sincerely hope that this information helped you to get r dun. Best wishes and God Bless.
Jan 26, 2009 | 1986 Plymouth Reliant 4 Door
Horizontal Lines
try another toner and see if it changes. if it does not then you may need a fuser,
Oct 16, 2008 | HP LaserJet 2300 Printer
Epson Stylus Photo 1280 InkJet Printer Logo
151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
