Question about NorStar M7310 Corded Phone
Call Park Issues..
How do I place a call on Park on a M7310 so others can pick up calls on their M7208 phones?
How do I tranfer calls to their phones?
  • ynotphone
    ynotphone May 11, 2010
    are you still having issues with this?
  • 192 Answers
Well to place a call on Park:
-> you should answer the call -or- be on a call
-> press FEATURE 7 4
-> then look at the display as it will give you a park number
Anyone can pick up a phone now, then dial that park number which you've seen - to answer the call.
To Transfer:
-> press FEATURE 7 0
-> then dial the extension you want to transfer to...
Now you can either stay on the line to tell the person who you are transferring and then hang up the phone -or- just hang up after dialling the extension to complete the transfer.
Posted on Mar 23, 2009
My M7310 won't forward a call to the next open line but gives a busy signal
Hard to answer because your problem description does not match the part.
Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
Dec 14, 2012 | Nortel Meridian M7208 Corded Phone
M7310 voicemail
You need to access Admin programming in the phone system and navigate to Capabilities and change the Forward No Answer to the DN of the voicemail....if unsure of any of this you need to be calling your vendor that handles the system for all issues or questions.
Dec 06, 2012 | NorStar Meridian M7310 Phone
My Norstar M7310 is stuck in handsfree mode. Is there a feature or programming fix for it?
Nothing in programming typically would help with exception to maybe swap by plugging in a M7208 into your problem jack then swap back to m7310 again. Going to 08 and back to 10 can sometime clears issues otherwise sounds like a bad phone and needs repair.
Oct 03, 2012 | NorStar M7310 Corded Phone
Norstar M7208, it's direct line number is diverting to another ph
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
Jul 01, 2010 | NorStar M7310 Corded Phone
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
Unable to transfer calls to a certain internal extension using a M7310 Nortel Corded phone
The do not disturb might be active on the extension that your trying to transfer to.On the extension that your trying to transfer to, enter feature #85 to cancel out do not disturb.
Sep 28, 2009 | Nortel Meridian M7208 Corded Phone
Cordless phone
Just about any one will do IF you get an Analog Terminal Adaptor made for your system. The ATA requires programming in your system, so it's probably best to call a Nortel service tech.
Before some smart sould points out that Nortel has a digital cordless, remember that the "T" phone doesn't work on a Compact 308 box. Besides, an ATA and a $50 cordless is WAY less expensive.
Carl
Jun 27, 2009 | NorStar Meridian M7310 Phone
Caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Sep 18, 2008 | NorStar Meridian M7310 Phone
Programming a phone to pick up calls
I need more information. When calls come in, does the triangles appear on the phones you want to pick up? Do you have all the lines on the phones? Is sounds like you want only the "ringing sound" to happen on your phone, but have it appear on the others. Is this correct??
Dec 14, 2006 | NorStar M7310 Corded Phone
NorStar M7310 Corded Phone Logo
138 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
