Question about Acer Ferrari 4000 Notebook
Computer shutdown by heat. - Acer Ferrari 4000 Notebook
  • Acer Master
  • 32,281 Answers
The overheating can be caused by :-
The fan has stopped working - needs replacing
The vents and or fan is blocked with dust - needs cleaning
When operating the laptop it needs to be placed on a flat surface so the vents on the bottom of the laptop are ubobstructed.
Posted on Jan 26, 2009
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Automatic shutdown
Check the CPU Fan and make certain it is functional. Some computers do an auto-shutdown when the CPU reaches a certain heat ratio upon starting. Make sure the power conncetion is on firmly.
Jan 13, 2014 | HP Computers & Internet
Automatic shutdown over heating
Turn the computer off.
Remove the side-panel, to expose the motherboard.
Turn the computer on.
When you see PRESS <blah> TO ENTER BIOS SETUP, press the <blah> key.
Use the "arrow" keys to move around the BIOS SETUP menu,
looking for any "system health" menu-entry.
Press the "enter" key to select that menu-entry.
It should report the current motherboard temperature, and the current CPU temperature,
and the temperature-limit, beyond which the motherboard will force a shutdown.
It may also report the speed of the power-supply fan, the case fan (if installed), and the CPU fan.
Also, take a look at the fans, to confirm that they are spinning.
Replace any non-functioning fans.
Jul 13, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
PC Getting auto shutdown
The most common reason of a PC getting auto shutdown is that the processor may be getting over heated.
Every processor has a TjMax temperature. when the processor reaches that temperature, it starts throttling(slow down) and if it continues to become more hotter then it automatically sends a shutdown signal to the Computer
Solution:-
  • Clean the Heat-sink.
  • Check the fan speed.
  • clean the cabinet.
  • use thermal paste over thee processor.
  • Make sure there is proper ventilation in your cabinet.
Hope this may help you......cheers:)..plz vote
Sep 24, 2010 | ASUS P5PE-VM Motherboard
My laptop keeps shutting off it is a hp pavillion dv6000
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 16, 2010 | HP Pavilion dv6000z Notebook
Aspire 5535 heats up and shuts down when a game is initialized. Fans clean and appears functional. Applied fresh thermal glue to heat sinks. Problem persists.
increase ur ram Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
Aug 29, 2010 | Acer Aspire 5050-3242 Notebook
I have a Acer desktop. after working for one hour it shuts down automaticlally. please help me.
Please check your Laptop Processor fan, if the fan stops working then the Processor got heat and system automatically shutdown or restarts
Dec 01, 2009 | Acer Computers & Internet
Laptop turning off
Often, if a system turns off every time at roughly the same time, it's a hardware problem. System gets too hot, shuts down, restart it and it'll run again for a while, but not quite as long, and continue like that. Can you feel/hear the fan moving air? Possibly clogged, see what you can do to get it cleaned up a bit. Does it make any difference what surface it's on? May be covering a vent on the bottom or back.
Oct 29, 2008 | Sony Computers & Internet
D300a shutdown
With the message you are getting on your screen,there are couple things you need to do.First thing you need to do is make sure your cooling fans are all working if they are your next step is to go out and get a can of compressed air to clean the heat sink on the processor and any other cooling fan that needs to be cleaned before doing this unplug your computer to be on the safe side.If the heat sink looks clean you may need to remount the heat sink using thermal paste.Remember after cleaning your computer try to clean it often this is one thing that most computer user's overlook.
Aug 09, 2008 | Insignia D300a PC Desktop
Computers & Internet Logo
144 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
