Question about Refrigerators
We have a whirlpool gold side by side refrigerator, model GS6SHEXML00, serial #SP2634486 - the handle is loose. How do we fix it?
  • 29 Answers
SOURCE: GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Posted on Oct 30, 2007
SOURCE: whirlpool side by side water dispenser not working
I had the same problem and it appear the cable set between the freezer door and refrigerator body has some wires broken. The cable is in the bottom right hinge. You can try moving the cable with fingers at the same time you're pushing the water lever.
While this is not going to be a permanent fix, at least it confirm where the problem is.
Posted on Nov 28, 2007
  • 15 Answers
SOURCE: door handle is loose on model#gsh22jftacc. how do you tighten?
If it's the same as the one we have (which is similar to the pic posted on yours) there's a plastic piece on the top and bottom of the handle that you have to pry up (gently) to get to them.
It looks like a line that runs horizontal across the handle, but it should come up with a little force (meaning it shouldn't require tools). You have to pry it from the side, not the top or bottom.
Posted on Mar 03, 2009
Maytag317
  • 1136 Answers
SOURCE: My side by side refrigerator handles are loose (Whirlpool gold)
Hi, Most newer models have a screw behind the plastic cover on the handle. Take a good look at the handle and see if the cover can be removed. It should just snap on. If not, please get me you model # and I can assist you further.
Thanks
Vic
Posted on May 14, 2009
Greg20
  • 149 Answers
SOURCE: refrigerator door handle is loose how do I fix it?
some come off when you pull straight up if there are no visible screws. then tighten the screws on the inside of the handle that fasten into the clips on the door.
Posted on Jun 12, 2009
I have a Whirlpool Gold Conquest refrigerator model number GS6SHEXML00. It is working properly except when I open the fridge door, the light doesn't turn on. The freezer light turns on correctly. I...
George Andraws, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (George Andraws), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 17, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side door handle is loose.I can't find the way to tighten. IT appears the screws are underneath the rubber gasket, but I am a little wary of tearing it loose without anew gasket.
Most door handles now are front repairable. I can't tell without the model number which style you have, but most units have an insert in the door handle. You have to pry this insert out, to get to the screws for the handle. Some handles actually clip on to the door by sliding the handle up or down to clip it on or off. Good Luck, Appliance Specialists.
Feb 04, 2010 | Refrigerators
Handle on fridge side is loose
Look at the top and bottom of the handle. There should be a plastic end cap you can gently pry off exposing the screws to remove and tighten the handle.
Oct 04, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a whirlpool gold side by side with ice and water. The refrigerator handle has come loose at the top. The screws all appear to be in accessible as they are directly behind the door handle.
See if you can unscrew the handle at the bottom, and slide it off the top bracket. Then you should be able to tighten the top screws and re-install the handle.
Jul 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My whirlpool gold side by side serial # slo539783 model #gd
Sound like you have a refrigerant leak I suggest to take it to a pro because you need lots of tools and knowledge to properly fix it And don?t let people tell you than is just to add refrigerant because that is a common myth or miss conception, refrigerant don?t ware out or burn out if the system need refrigerant is because there is a leak some where.
Jun 07, 2009 | Whirlpool Refrigerators
ICE MAkER HANDLE PROBLEM
If your model is the Whirlpool Gold I can possibly help you.
Whirlpool Gold GD5NVAXSY need model number to got to service manual. Sorry, but manual people don't realize how many versions of refrigerators. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Jun 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Thanks
Vic
May 14, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL REFRIGERATOR
my refrigerator gold is running but not cooling I have the model number and serial numbers if that is helpful please help
Apr 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
