I am getting an error message when booting PXE-E61
No find the op system. The harddrive is spin up. The DVD is spin as well. I have tried the recovery disk as well it does see the harddrive. I have put it on a USB adapter kit and It see the harddrive. It says to check the Media cable.
  • 3,940 Answers
The hard drive is most likely failing. It is being detected but is not functioning (when a boot device isn't seen or fails to boot, the system trys to boot to network and that causes the PXE error.
Most likely, since the drive detects, but doesn't work, replace the HDD
Posted on Jan 26, 2009
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
My acer aspire 5538G won't boot, i get a message saying error PXE-E61: media test failure check cable PXE-MOF exiting broadcom PXE ROM operating system not found.. and i am unable to use disk to disk...
Your computer is attempting to boot over the network (something that only works with a server on the network) PXE E61 Media Test Failure Error
You can get this message if the boot device order is wrong in your computer (go into bios and check) but more often, the computer has tried to boot from the hard drive and dvd and failed before trying to boot from the network. It sounds like the hard drive has been failing for a long time and is now so bad the disk to disk no longer works. Replace the hard drive and reinstall using the recovery DVDs you created. If you didn't create them, you may have to contact Acer for a set.
May 05, 2017 | Computers & Internet
My Acer Aspire 5100 keeps rebooting. This is what the screen says: INTEL UMDI PXE2 REALTEK RTL8139 PCI FAST ETHERNET CONTROLLER PXE-E61: MEDIA TEST FAILURE CHECK CABLE PXE-M0F: EXITING PXE ROM That is all...
The error message means that your system is trying to boot from LAN ie... Network boot enabled in your BIOS.
Since the system can't find any where to boot from. It is restarting.
Also probably your bootloader on the harddrive is corrupt. Please reinstall the operating system using a CD/DVD.
Jul 11, 2010 | Acer Aspire 5100 Notebook
Upon booting I get this error. for realtek
PXE means Pre-Boot Execution Environment. You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error.
You have to replace the hard drive and reinstall the operating system?
Jul 09, 2009 | Toshiba Satellite P205-S747 PC Notebook
When I try to boot up my Compaq Presario 2500 laptop I get the following error message: PXE-E61: Media test failure, check cable Operating System not Found. I have tried changing the boot sequence in the...
Boot sequence isn't enough. You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
Jun 06, 2009 | Compaq Computers & Internet
I have a problem geting my recovery disc to work in my compaq presario 2200 laptop, as i have just installed a new harddrive iam getting a PXE-E61: Media test failure and PXE-M0F Exiting PXE-ROM. ldygolfer
You need to change the boot order in the bios.
When you start the computer screen should prompt you at the bottom with something like:
F2 or F10 to enter setup.
Once you're in the bios, change the boot order to cd / dvd first.
Right now it's trying to boot through the network, that's why you're getting that message.
Let me know if you need any more help.
Best of Luck!
Feb 24, 2009 | HP Compaq Presario 2200 Notebook
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
Possible hard drive failure on SLIMNOTE N12PI
I don't think its a hard drive failure thats causing that message, basically PXE means your computer is trying to boot from a network/server. All you have to do is go into your BIOS setup right after your computer boots. Then make sure your BIOS is set to boot from your hard drive and not anything else (floppy, network etc.). And if possible disable any PXE settings.
Dec 30, 2008 | Twinhead SlimNote N12PI Notebook PC
PC will not boot.
Hi , without explaining all that is happening ,your pc harddrive has failed.The pc is looking for an operating system but cannot find it.
Dec 08, 2008 | Toshiba Satellite A135 Notebook
Power or boot failure
PXE is a common term when a computer is trying to do what is called a network boot. you probably have a bad hard drive and the computer sees there is no harddrive and is trying to boot from a pxe server off of a network.
Jul 28, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
323 people viewed this question
David Payne
David Payne
