Question about RCA 20F424T 20" TV
Picture color issue
My picture turned yellow all of sudden. Color Adjustments made no change
    Champion:
  • 252 Answers
The tv need to be open because ,their's a lose connection of the CRT section and it needs to resoldered
Posted on Jan 26, 2009
Why are my photos taken with my iPhone 5 suddenly coming out off color and very dark?
First, I suggest you look into the camera lens. Perhaps it is not clean? Next, how does the preview image look before snapping the picture? If the preview is good then the problem may be in automatic post-process settings.
May 10, 2014 | Apple iPhone 5
I just purchased a Sanyo Hdtv Lcd and the picture quality if off the picture seems to come out greyish or pale....i'm not getting a true color. Is there some adjustments that I should know about? I tried...
Check hookup connections. If you are using the component input (3 wire video green ,blue and red). Be sure both ends are in the correct colors. if switched or not all 3 connected color will be off. Composite video uses only 1 wire ,yellow. See owners manual for hookup explanations.
Mar 07, 2011 | Televison & Video
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a RCA 42 inch 1080 HD Tv. My son decided to change my color setting. Is there a way to get the factory setting back? I have been playing with the different tint, contrast and color settings. I still...
well there is usually a tab in your pictuer adjusment screen that says reset. but if your tv doesn't have that tab i can give you a few adjustments.
first- your tint should remain neutral. so if it has a color scale of 1 to 100 it should be on 50
second- your contrast should be about 80% or what your eye likes. look at the black tones
when you are adjusting it.
third- your brightness would look good about 65% pay attention to whites in your picture
fourth- your color all depends on how your eye precieves it. so adjust it with out making the colors to
neon or too dull
fith- your sharpness should be turned down to about 15% to much gives the picture a grainy texture.
sixth- your color temp should be neutral or normal. if the tv gives numbers the selection that says 6500k is the best choice.
you could always buy a calibration disc for about $20 and that could help you even better because now you are using images targeting the individule adjustment.
you could always pay to have it profeesionally caibrated. ISF certified techs will come too your home and do all the adjusment with special color filters and light sensors to give it the best picture possible according to your room. i know best buy charges $250 for it
those are just some suggestions. and the adjustments i give you work greatest for me, so if you dont like the overall out come you can always tweek it to your eye. make sure you use a digital picture with a lot of color when your making your adjustments. i like using disneys "the incredibles"
Jan 26, 2009 | Televison & Video
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Isignia DVD RW suddenly lost color. I now only see B&W
I think u are using the component out to view, right.
First of all see whether u can see a yellow color RCA jack labeled video out.
Try using tht output and post back
Nov 18, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Pioneer DVR-520H DVD Recorder Picture is Yellow
If running component or RGB try replacement lead set. Otherwise is TV issue.
Oct 12, 2007 | Pioneer DVR-520H DVD Recorder
Component color turns yellow
when you say color. Do you mean gray scale like what if you turn off the color completely?? Does the picture look B&W? need to know this?
Jul 01, 2006 | Mitsubishi WS-48311 48" Rear Projection...
RCA 20F424T 20" TV Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
