Question about Whirlpool Duet GHW9150P Front Load Washer
Water leaks The water is leakin from the spot where it fill inot the detergent, area. It was also makin noisw while spinnin, like athe rubber seals rubbin.? Or like something was caught up in the spin cycle, ? I t is only about a year old.
I had similar issue. Fill tube running from the bottom of detergent tray to the washer drum was plugged.... (by a sock!!!). How did it get there? I'll tell you. You see the drum seal (around the inside of the door) is not a tight seal. You can actually reach up behind it from where it meets the top of the drum. Anyway in my case, a sock made it's way through that seal and outside the drum and into the drum containment vessel. So when the drum spun (to dry the clothes and empty the water) it made a terrible noise. The sock became lodged at the base of the fill tube opening and plugged it thus not allowing any water into the drum. Instead, when filling, the water just flowed out from the bottom of the detergent tray and onto the floor. I hope this helps.
Posted on Jan 29, 2009
Washerleaks when filling why
Good Morning Friend,
I understand that the washer on your Frigidaire laundry center, model# FEX831F, is leaking water while it is filling. Listed below are some options that you can check first.
    1)There might be a loose hose connection either at the faucet or on the washer. Check and tighten the hose connections. Also, make sure that the rubber sealing washers are installed. If the rubber sealing washers are not there, this can cause leaking.
    2)Check and make sure your houses drain pipes are not clogged. If they are, unclog the drain pipes. Contact a plumber if necessary.
    3)Make sure you are not using too much detergent and are using "HE" detergent. If you are either using too much detergent or not using "HE" detergent, this can cause oversudsing, which can cause leaking.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 22, 2014 | Frigidaire FEX831F Top Load Stacked Washer...
Leaking from underneath the machine
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Dec 31, 2010 | Hotpoint VBSR3100D Top Load Washer
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi, rear footwell is filling up with water behind drivers seat. seems to be happening after heavy rain. Not sure if door seal problem or bung thing being clogged up under battery as some sites seem to...
It's probably coming from the sunroof drains being clogged.
Open the front door, look closely, you will see a rubber tube sticking out 1 inch. Cut off the tips so the tube is wide open.
Nov 16, 2009 | 2003 Volkswagen Passat
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
Leaking tank
(1) Does water or chemical leak from the tank when filled, but before it is installed? If not, then the tank is OK.
(2) If the tank is not properly aligned to the lower handle when assembled and latched, the black rubber seals on the handle will not seal to the tank. You may wish to look at this. Also, make sure both round black rubber seals are present on the flat mount where the tank valves will sit.
Oct 05, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
My bosh is leaking
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Oct 31, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Leaking door due to the wire ring that holds rubber seal
Bosch Nexxt 500 WFMC3301 Front Load Washer how
to get the metal ring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 06, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
172 people viewed this question
Dan Webster
Dan Webster
Sal De
