Question about Combi All- in-One Activity Walker
Need to changej battery in steering wheel - Combi All- in-One Activity Walker
2006 Ford 500 steering wheel locked or power steering not working. Check system alert and battery light turns on.
Call your Ford dealer and ask them if you car has a locking steering wheel.
Since "forever" ago, there was a were "star wheels" attached to the inside of the steering column, for the purpose of preventing theft by locking the steering wheel when the key was removed.. The bad side was that those locks can jamb if the steering wheel
is at the end of it's travel, such as can happen if the front wheel of the car is jammed against a curb when parked.
Your fix might just be to turn the steering wheel whilst trying to start it, though it may take a little muscle.
God bless your efforts.
Jul 04, 2017 | Ford Cars & Trucks
Remove steering wheel from a 1992
1992 what ???? if you have air bags you must first disconnect battery ,remove air bag and horn assembly next you'll need to remove the steering wheel locking device (there is a special tool ) then with a mark possion of steering wheel before removing retainer nut, next you'll need a steering wheel puller,reassamble in reverse order.
Aug 06, 2014 | Cars & Trucks
Remove steering wheel on 85 dodge diplomat
Disconnect the negative battery terminal. Remove the horn pad on the steering wheel-Phillips head screws from the back side of wheel. Then loosen the nut on the steering wheel center. Mark the steering wheel to column shaft position, so the wheel goes back in exact same position on the shaft. You may need a steering wheel puller to get the wheel off the shaft, not always, but sometimes the wheel is on pretty tight. Do not hammer on the wheel to get it off, use a puller if needed. These pullers are at parts stores and not expensive.
Dec 31, 2013 | 1985 Dodge Diplomat
How do i remove a freelander steering wheel
Ok, here it goes;
  1. Make SRS Airbag system safe, disconnect BOTH battery leads and wait 10mins for SRS battery to discharge.
  2. Remove two torx screws securing Airbag system (rear of steering wheel).
  3. Remove Airbag Module.
  4. Disconnect SRS connection.
  5. Disconnect steering wheel multiplug.
  6. Make steering wheel and front wheels central.
  7. Hold wheel and release/loosen big-fat-centre-nut.
  8. Pull wheel from splines.
  9. Remove and discard big-fat-centre-nut.
  10. Remove Steering Wheel.
Jan 29, 2013 | 2003 Land Rover Freelander
How to remove steering wheel
Disconnect battery,,,,,,,,remove screws from back of steering wheel cover.. front of steering wheel cover will come off and may be plugged into steering wheel carefully remove wire plug from tab.remove large nut on center of steering wheel , use puller kit from local auto parts store , prob wont come off on its own but might . BEFORE removal note location of scratch on wheel , matching scratch on post for alignment of wheel on replacement ,slide steering wheel into place, tighten nut just enough, replug wire and dont make screws too tight re hook battery and reprogram radio.... sorry.. yur welcome
Jan 13, 2012 | 1997 Acura CL
I need a new steering wheel for a BMW318ie LHD (1997)
disconnect neg battery lead, from underneath the steering wheel remove 2 torque screws and carefully remove airbag unit disconnect the 2 wires underneath it first, remove bottom steering column cover, next remove keys and allow steering lock to engage with the road wheels pointing straight ahead remove wheel centre stud, wriggle bump shake steering wheel till it slips of splines disconnect wires from underneath and remove wheel, installation is reverse, make sure you position steering wheel straight ahead, dont reconnect battery till airbag unit is reinstalled or you will get a warning light illuminating.
May 16, 2010 | 1997 BMW 318
I need to know how to take off a steering wheel from a 2002 chevy pick up truck
1 remove negative battery cable 2 remove air bag module from steering wheel, this is usually bolted thru from the back of the steering wheel 3 remove steering wheel retaining nut. 4 Using a steering wheel puller pull steering wheel from steering shaft.
Mar 16, 2010 | 2002 Chevrolet Silverado
Needs key cylinder replacement
This first post is WITH AN AIR BAG:
With Air Bag Before removing the steering wheel, disable the air bag system
Disarming the System To disarm the air bag system, simply disconnect the negative battery cable from the battery. Isolate the battery cable by taping up any exposed metal areas of the cable. This will keep the cable from accidentally contacting the battery and causing deployment of the air bag. Allow the system capacitor to discharge for at least 2 minutes, although 10 minutes is recommended, to allow for the dissipation of any residual energy.
CAUTION Before removing the steering wheel, disable the air bag system (refer to Section 6). Failure to do so could result in accidental air bag deployment and possible injury.
  1. Disconnect the negative battery cable and disable the air bag system.
  2. Set the front tires in a straight-ahead position.
Exploded view of the air bag module mounting
  1. Remove the air bag module retaining nuts from behind the steering wheel.
  2. Remove the air bag module.
  3. If equipped, remove the cruise control switch.
  4. Disconnect the horn wiring.
  5. Remove the steering wheel retaining nut.
  6. Scribe a line mark on the steering wheel and steering shaft if there is not one already.
Use a puller to separate the wheel from the column
  1. Remove the steering wheel using a suitable puller.
To install:
  1. To install, align the scribe marks on the steering shaft with the steering wheel.
  2. Ensure the wheel compresses the 2 locktabs on the clockspring.
Oct 11, 2009 | 1993 Jeep Grand Cherokee
How do I remove the steeringwheel from a 1997 toyota tacoma v-6 4x4
you must removwe the airbag first. disconnect the battery for at least 10 minutes before you start. on th sidecover of the steering wheel you will find two covers that you must remove. underneath these covers you will find two # 30 torx screws. loosen these screws. they will not come all the way out. once they are removed lift out the airbag. carefully disconnect the airbag wiring. there is a 17mm nut holding the steering wheel on , remove it. at this point you can try to wiggle the wheel off but you will probably need a steering wheel puller. you would be much better off letting a professional handle this.
Oct 01, 2009 | 1997 Toyota Tacoma
Combi All- in-One Activity Walker Logo
74 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
