Question about Brother MFC-7860DW Compact Wireless All-in-One Laser Printer, Copy/Fax/Print/S
How to change language to english. brother fax 7860dw printer
SOURCE: Change Language on Brother MFC-215C
PLEASE, can anyone be sure of the eeprom code for GB before I start the procedure, I tried to contact the hotline but I'm not sure of their phone number either.
Thanks for ur help
Posted on Jun 02, 2008
jonags3
  • 83 Answers
SOURCE: change LCD language to English on Brother MFC-3240C
Gud Day!
Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
Please rate the solution after you have tried it so that I can assess you more on this problem.
Jonags
Posted on Dec 11, 2008
SOURCE: Brother HL-1440 Printing Preferences Language Problem
I had the same problem. I finally totally uninstalled the printer from my computer, downloaded the "new" software from the Brother site, and reinstalled it. This is what finally worked for me (WinXPProf.).
Posted on Jan 18, 2009
  • 320 Answers
SOURCE: want to change its language from Norweign to English
i hope that you have the manual, it should tell you how to change the language when you do a machine set up, press menusey button and start scrolling throgh the different menu good luck
Posted on Jan 20, 2009
SOURCE: changing language from french to english
http://safemanuals.com/zearchres_134.php this site allows you to get the manual for the machine this should help,
Posted on Jan 23, 2009
After replace toner keep geting message JAM INSIDE but there is no jam papper
I have a brother printer too, nine times out of ten you have to make sure everything is closed tight
May 30, 2015 | Brother MFC 7860DW - Multifunction fax /...
Why do printouts have increasingly larger blank margins?
Go to the printer's settings menu and look for an option to "Restore Default Settings" or similar words.
Jul 30, 2014 | Brother MFC 7860DW - Multifunction fax /...
How to change language in english
Available LCD languages are English, Spanish, and French. The "Basic Users Guide" describes controlling this... http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=FAX2840#.U7Qav9Ig__8
Jul 02, 2014 | Brother FAX-2840 Fax
Says manual feed. Load paper
There is a manual fee slot just above the paper tray. Sounds like the manual feed slot isn't closed all the way. Here's a link to support for your machine: MFC 7860DW Others Brother Solutions Center Note there is a firmware update available.
Jun 19, 2014 | Brother MFC 7860DW - Multifunction fax /...
How to change language on Brother FAX-930 . I have on Fax Germany language , buth I need english . Can I do it ?
  1. Turn off the P-touch.
  2. While holding down the Shift key and the "R" keys, press the On/Off key once and then release the "Shift" and the "R" keys.
  3. "English" should be on the display and then press faq_ans_70_return.jpg.
    If "English" did not display, repeat steps 1 thru 2.
  4. "inch" will be on the display, press the "Enter" key.
  5. Set the Date (MM/DD/YY) and Time (hh:mm)
Still having Problem Then follow Us For Brother Printer Support
Feb 19, 2014 | Brother FAX 930 All-In-One Thermal Printer
Change printer language brother printer
Found below instructions - should work to change from chinese as well.
Your Brother machine's LCD can display information in English or Spanish. The default language is English.
To change the language on your Brother machine's LCD, follow these steps:
  1. Press Menu, 0 (Initial Setup), 0 (Local Language).
  2. Press the Up or Down arrow key to choose English or Espanol.
  3. Press the OK key.
  4. Press the Stop/Exit key.
Oct 04, 2013 | Office Equipment & Supplies
My brother intellifax printer instructions is in French, and I would like to change it to english
press menu go down to "reglage initial" press ok or set
go down to "language local" press ok or set go down to english or "anglais" and press ok
Jan 08, 2010 | Brother IntelliFax-2480C Fax
Want to change its language from Norweign to English
Jan 13, 2009 | Brother FAX-T74 Plain Paper Thermal...
Brother MFC-7860DW Compact Wireless All-in-One Laser Printer, Copy/Fax/Print/S Logo
48 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
