Question about Frigidaire FGF378AC Gas Kitchen Range
Frigidaire Stove clock resets to 12:00 when igniters turned on
New Frigidaire Stove (model FGFL87GSG) clock resets to 12:00 when stove top igiters are turned on.
  • gaffney66 Apr 09, 2009
    same reset problem.  Had the local appliance contractor out, said he's never seen such an issue before.  Replaced the entire clock module, problem still here.  Appliance contractor apparently beat out of Fridigaire that the know this is a problem but don't have a solution yet.  They say a polarity problem between the ignitor circuit and clock.  Contractor is coming next week to "move some wires around".  Not a very encouraging solution.
I have the same problem. This is an intermittent problem, maybe once every 20 to 30 starts the clock goes resets and the appliance beeps just like if unplugged it and then plugged it in again. I’m an electrical engineer and this sounds like the microcontroller that runs the appliance is being reset by noise caused by the spark igniters. This is definitely a design problem. Separating the wiring of the igniters and the control board should help. When I get a chance I’ll have to connected an oscilloscope and look at the noise. The control board microcontroller reset pin probably needs an RC snubber or an isolated ground. If /when I find something more definite, I’ll place another posting.
Posted on Jan 18, 2010
  • sss3141592 Feb 07, 2010
    Fixed it.
    Putting an RC snubber across the AC input of the igniter module will fix the problem. The igniter generates high frequency, high amplitude noise that causes the PIC microcontroller on the control board to reset. A snubber damps out these high frequency oscillations and prevents the microcontroller from resetting. You can buy them premade or make one yourself. I used a .022uF, 1000V ceramic disk capacitor in series with a ½ watt 47 ohm resistor. Solder one lead of the resistor to one lead of the capacitor. Use heat shrink tubing to insulate the exposed leads on the resistor and capacitor. Cut off original female spade connectors and crimp in the snubber with the wire. I’ve run in this configuration for a longer than a month and no more reset problem. Maybe Frigidaire could do a little more product testing before we have to correct their engineering mistakes.
  • Dudley, Shannon McFadden
    Mine has the same symptom and I will try this solution. I see the Spark Module on the parts diagram but it's not clear from the diagram where on the range the Spark Module is. Can you please give a hint as to how to access the Spark Module (from below the whole range, under the main top panel)?
Local contractor came back. Said 6 other people have reported the problem according to Frigidaire.  Wasn't home so I don't know exactly what they did but they claimed to have moved some wires around.  So far no problems.  Electrical engineering friend said that they likely swapped some ground connections around so that when the ignitor draws current it doesn't drop the voltage of the whole system.  Not sure if a homeowner could troubleshoot and solve this one without directions from manufacturer.
Posted on Apr 21, 2009
My stove panel went blank.
You will need to replace the clock/timer on the unit. Here is that part to order.
Frigidaire 316557114 Clock timer AppliancePartsPros com
Mar 22, 2014 | Kitchen Ranges
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
What is a f13 error code on a Frigidaire Gallery smooth top stove
Hi danair2,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Aug 14, 2009 | Kitchen Ranges
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
AMANA STOVE
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Mar 10, 2008 | Amana RanARG7302 Gas Kitchen Range
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FGF378AC Gas Kitchen Range Logo
758 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
