Question about Garden
Engine drags while trying to start
5 year old -48'' cut cub cadet riding lawn mower. 18 horse briggs engine. When mower was a couple of years old, engine started dragging when you tried to start. It would always start. Kept getting worse, Changed out battery-no change, changed starter, no help, cleaned ground connection, no help.In the past, after it started and you drove it a while, turned off-then restarted-it would start with out dragging.Yesterday it would not start -even after putting a 125 amp. charger to battery.Any suggestions? Starter solinoid maybe?
  • 3 Answers
It may be a problem with the camshaft-compression release. Some of the Briggs & Stratton models had a weak spring on the compression release whis is parts of the camshaft. you may also want tocheck that all wires are clean and tight. Also if it's a over head valve model check the valve clearance.
Posted on Jan 26, 2009
How to replace throttle cable rzt 50 cub cadet briggs motor
You will need to remove the left fender/tank to access the throttle lever mounting screws. Make either written notes or take snap shots as you remove the old cable as there are several different setups for this mower series so you can install the new cable correctly.
Feb 10, 2015 | Cub Cadet Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
May 12, 2012 | Cub Cadet Garden
Cub cadet lawn mower won't start and i have changed everything
What have you changed?? What model lawn mower is it? Is it a riding lawn mower or a push lawn mower? Does it turn over(engine turning with the starter), or does it do nothing when you turn the key over? I have serviced cub cadets for almost 20 years, from the very first model(1959) to present, and i own 13 different tractors myself. if anyone can help you, i should be able too. i just need more info about the unit and its problems. i look forward to helping you.... -Brian-
Oct 25, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Oil for brigg and stration engine 18 horse
I assume you are asking what type of oil it requires? sae30
Aug 04, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Runs for 25 minutes then shuts down like its out of fuel
try taking the plunger off the fuel shutoff solenoid on the bottom of the carb
Jul 01, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Replacing governor on Cub Cadet 1225
I have a cub cadet 1864 and the governor is out of control, the engine will race a high speeds. When i pull back the governor arm and hold it it run normal. Can some one help
Apr 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
528 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
