Question about GE GLDT690TWW Dishwashers : Built in Dishwasher
Model GLDT690t00ww shows 2 PCB's WD21x10357 and WD21x10389, won't start just one leg of the LED will light.
One leg of LED lites up with delay and also the start when you touch each of three buttons. Each has a different leg that lights. These are a main control board with 2 small interface boards with 3 harnesses. I put in the cheaper Wd21x10357 and the harness between each interface boards was too short by 2 inches.
catriver
  • 878 Answers
SOURCE: GE GSS22SGMC BS s x s freezer frost build up
Jake, the green wire is the ground, just attach it to one of the screws the secure the cover plate. As far as you ordering both the heater and the board, you have it covered. Catriver.
Posted on May 30, 2008
abhishek33
  • 1239 Answers
SOURCE: GE WHRE5260E1CC NO HOT WATER
hi If the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Posted on Sep 13, 2008
BIKER T
  • 909 Answers
SOURCE: main board
You will find the key pad needs to be replaced. you will need to remove the outer case first then unplug the ribbon cable and unscrew the earth screw. Peel the front keypad off carefully then replace the same way with a new one.
Posted on Nov 12, 2009
SOURCE: GE WPRB8050 Profile Washer...control board problem??
not draing
Posted on Jul 30, 2010
livewire874
  • 618 Answers
SOURCE: My washer control panel is
try unplugging the unit for 10 min then plug it back in and try again.
Posted on Oct 27, 2010
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Jandy lite 2 pilot won't start
check fuses that go to ignitor if ok ohm out ignitor when unplugged should be about 78 ohms if shorted or open replace if ok check safety circuit
Apr 20, 2013 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
Won't start dial shows h:01
You have set the delay start. Press the button that says "finish in" or "delay start" (depending on the model) unit it is zero. Either that or you have entered the hardness setting and this should come off by just turning to the off position. Some of these d/ws aalso have a reset which is acheived by pressing two buttons simultaneously and this should be printed on the panel (dot under each button joined by a line) or hold the start button. (You haven't supplied the ENr so I have tried to give all possible scenarios) Post ENr if none of the above works.
Mar 19, 2013 | Bosch Dishwashers
Purple light is on and cycle won't start
It's possible that you have put the dishwasher into delay mode. Try powering off at the powerpoint as this will force a reset of all programming.
The pause/start button also sets the Delay Start feature which can delay the start of a wash program
from 1 to 12 hours.
To cancel Delay Start
Press the I button.
Dec 30, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
What kinds of a flashlight the brightest?
Check out this WEB site for super bright LED flashlights.
http://www.nextag.com/super-bright-led-flashlight/stores-html
Nov 28, 2011 | Camping, Backpacking & Hiking
1999 tahoe, was running rough, I changed the plugs,that didn't help. Then for no reason it ran like new, then is was stalling and wouldn't rev up, Then it wouldn't start at all. I noticed no...
now that leg won't lite up and the fuel pump won't work ????? The PCM - engine computer supply's B+ voltage to control the fuel pump by energizing the relay .
GM Fuel Pump Relay Testing
Jun 05, 2017 | Chevrolet 1500 Cars & Trucks
I have a convection bread maker. I made one loaf of bread tonight and i unplugged the machine. 30 minutes later, I tried to make a second loaf ant the menu select wouldn't work but the start and mix in...
Cuisinart has many different bread machine models. Next time you ask a question, please include a model number. Thank you.
Here's my generic best advice for you dear:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press and hold the Select button down until the unit powers up.
    5. Some models require you press and hold the Start button down until the unit powers up.
    6. Some models require you select a mode first by pressing the Select button.
    7. Some models require you press and hold the Stop button down until the unit powers up.
Were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Yes, Fantastic! Now reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button. Others require you press and hold the Select button.
Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Jun 13, 2011 | Cuisinart Kitchen Appliances - Others
I replaced the fuser in a Brother HL5170-when I turn it on, all 4 lights are blinking. What might be the problem?
This is what's called a Service Call, meaning the machine has experienced a problem that it doesn't think an end-user can support.
According to the manual:
"Push the Go switch and the Job Cancel switch at the same time during the service call and hold them. And then push the 2 key additionally to show the service call type by LED combination."
Which I'm assuming means press and hold the two buttons, then press them both again.
The combination of the LEDs tells you where the problem is:
RED Status +:
Toner LED = Fuser (Fixing Unit)
Drum LED = Laser
Paper LED = Main Motor
YELLOW Status +:
Toner LED = Main PCB
Drum LED = Engine PCB
Paper LED = DIMM
All of which are expensive parts and also expensive repair.
Oct 12, 2010 | Brother HL 5170DN Laser Printer
Wd-52525 lamp light not resetting
Good Day;
1. Check for an open AC fuse F9D00, if open check for a short on the 340v line to the lamp ballast between pin 1 an 5 at connector PL on the Power PCB, if shorted replace PWB-POWER LAMP (Ballast) part # 939P978010 and F9D00 part # 283D131040 2. Check for open AC fuse F9D00 part # 283D131040, if open check for proper seating of connector K1 on the Power PCB
Dead unit wd52525 mits
NO POWER
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A 1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck big IRISH.
Oct 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
GE GLDT690TWW Dishwashers : Built in Dishwasher Logo
69 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
