Question about FontLab TransType Pro for Macintosh V3.0 (TRANSTYPEPROFORMACV30)
FontLab 5.0.4 corrupted file
Dear Sir/Madam
The following problem occurred during my work in FontLab studio 5.0.4 Mac OSX: my computer broke down. I managed to save the following file that I am sending you as an attachment and I ask you if you can help me in any way I would be very grateful.
When I try to open the file in the fontlab I get this message “Import failed for the following reason: FontLab Font File is corrupted and cannot be opened. Use backup copy of the font file.” Because the computer is broken I do not have access to the file so this is my only chance to get my font. Do you have any idea or some means of how to recover the file or part of it?
Thank you very much in advance.
Lasko Dzurovski
MY Mac G5 OSX 4.9 needs updating to Leopard OSX.5
You must purchase a full retail version of Mac OS X 10.5 Leopard. You can find it on eBay.
Nov 25, 2013 | Computers & Internet
Setting password on OSX tiger
I taking it that you mean you want to change your password on a mac you have already logged onto. This is quite simple go to the apple menu which is located at the top left of the white menu bar, then go to system preferences and select network. Once network preference pane has come up click on the account called my account on the left hand side then on the right hand side there is a change password button, click on this and insert your Old password and then insert the new password in the New password box and then the new password in the Verify box. Then click the change password button on the bottom right. Hope this helps.
Jan 08, 2012 | Computers & Internet
The power come on but the harddrive will not boot since there is nothing shows on the screen. The screen is blank, no apple sign, no sping gears. pls what do i do,and my mac os that comes with the system...
With regards to the blank screen, this usually indicates an issue with the hard drive being faulty (hardware) or the OS might have corrupt system files (software).
These are the items you will need before we begin:
A. Mac desktop/laptop B. Mac OSX Installation DVD
A. Software Related
1. Power on the Mac computer/laptop and immediately press and hold the option key. 2. After about 15 seconds of holding the option key, release it and insert the Mac OSX DVD. 3. The DVD should load and display on-screen (along with any additional drives available on the system). 4. If the hard drive icon appears, then click on it. (if the hard drive boots the OS, then the issue is software related. Skip down to Section B, step #1). 5. If the hard drive did not appear, then the system does not recognize it. However, the DVD icon should have appeared, click on it. 6. The DVD will boot and begin the installation process. 7. Follow the installation prompts. 8. Once completed, the desktop/laptop will reboot and after logging in, will execute the registration process. 9. Complete the registration exercise and access the desktop. 10. Perform a software update and download all system and application updates to their latest versions.
B. Hardware Related
1. Power on the Mac computer/laptop and immediately press and hold the option key. 2. After about 15 seconds of holding the option key, release it and insert the Mac OSX DVD. 3. The DVD should load and display on-screen (along with any additional drives available on the system). 4. If the hard drive icon appears, then click on it. (if the hard drive boots the OS, then the issue is software related. Restart the computer and skip up to Section A, step #1). 5. If the hard drive did not appear, then the system does not recognize it. However, the DVD icon should have appeared, click on it. 6. The DVD will boot and begin the installation process. 7. Close the installation application and select "Disk Utility" from the "Utilities" menu option. 8. When Disk Utility loads, look to the left-hand pane and locate your hard drive (if detected). If so, click on it and format the hard drive then reboot and skip up to Section A, step #1. If the hard drive is not detected, then the hard drive has malfunctioned and needs to be replaced.
Hard drive's cost from $40-100 for sizes ranging from 40GB to 1TB. Once the hard drive has been replaced, you can install OSX from the installation DVD.
Aug 11, 2010 | Apple PowerBook G4 Mac Notebook
My w550 it is stoping when i make a call
there might be corruption of the firmware of ur device.u need to update it via mobile browser or by computer
if u want to update via ur mobile open browser cliuck on services.from here u can update ur mobile firmware.
by pc u need to download update software from sony ericsson website and then u have to follow the listed steps.
Mar 30, 2010 | Sony Ericsson W550i Cellular Phone
When i send a file to print from my mac (OSX 10.4.11) i get the error message in the printer box ''Printer not responding''I am using the HP 2500 Color LaserJet printer. It was working fine and just...
Connect the computer via fire wire to another working one.. and remove the two sleep files. Start your MBP holding down the T key The issue is a corrupt sleep file. once deleted your computer will work perfectly
Nov 11, 2009 | HP Color LaserJet 2500L Laser Printer, up...
Blinking folder with ? mark blue screen
yes youve just had a corrupted osx. use the osx disks supplied to you with the laptop to re-install
1. take the cd out of the paper case
2. inser the cd into the laptop
3. press power and hold "C"
4. wait..wait..wait
5. it will start setup and follow instructions.
if it doesn't install, you need a new hard drive.
Mar 03, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
When installing the 6310 all in one printer, at a certain point I get the following message: "The application HPIO Trap Monitor quit unexpectedly. Mac OSX and other applications are not affected. Click...
There are two ways for install the Scanner using only "the driver" and using "HP Photosmart Studio Includes Support for Mac OS X v10.3, v10.4 and v10.5 (Leopard)" using the driver not include IRIS OCR software only the driver to scan and thats why say "An OCR error ocurred, couldn't create file". Installing the HP Photosmart Studio fix the problem.
If fixed the problem visit my page www.richardsite.com.mx
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Need to find an upgrade for JamStudio to MAC OSX
if you have a power pc you could get an os9 version and run through classic
Jun 28, 2008 | KB Gear Jam Studio Graphic Tablet
E mac computer
Is it a file or Folder on the screen?
Are you booting in OS9 or OSX?
Simple answer without knowing the answer to the above questions could be the hard drive is bad. Try rebooting with the install cd's that came with the machine. If you see a disk image it is good if not it is bad. If in Os9 it is a corrupted system folder and that could mean many issues have occurred.
Apr 28, 2008 | Apple eMac G4 Desktop
Computers & Internet Logo
131 people viewed this question
Top FontLab Computers & Internet Experts
David Payne
David Payne
Are you a FontLab Computer and Internet Expert? Answer questions, earn points and help others
