Question about Zyxel Prestige 660R Router (P660R)
ZyXEL P-600 Series Compact ADSL2+ Router - Zyxel Prestige 660R Router (P660R)
Silverblade
  • 173 Answers
SOURCE: Problem connecting to Router with Mac Airport
The $ sign or a hash character before the network key only works with WEP 64 bits on Mac, if you enabled WPA(is it TKIP or AES?) make sure that your Mac computer supports that kind of authentication if not try to lower down the security level on the router by using WEP instead of WPA.
Posted on Nov 06, 2008
SOURCE: DRIVERS FOR MODEM ZYXEL PRESTIGE 600 SERIES
Try here http://www.zyxel.co.uk/web/support_download.php
Posted on Dec 17, 2008
ziraffa
  • 827 Answers
SOURCE: I need to secure my 600 series zyxel wireless router
Type 192.168.0.1 into your internet address bar. (If this doesn't work try 192.168.1.1 or 192.168.2.1 or whatever your router's ip is)
It will ask you for a username and password. The defaults are:
username: admin password: admin
or
username: admin password: 1234
Now find the Wireless Security section, or suchlike, from the menu and choose either WEP or WPA (stronger encryption) and Enable.
Remember to write down your passphrase somewhere safe!
Chris (ziraffa)
Posted on Jan 16, 2009
SOURCE: how to secure zyxel 600 wireless network
My nissan p 11 swithces off when in motion. plz asstst
Posted on Jun 06, 2009
Geekman
  • 32281 Answers
SOURCE: I have realizes that my zyxel 600 wireless router
To secure youe wireless router, follow these instructions : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Posted on Oct 17, 2009
Zyxel tm6841g default
This page gives you how to set up this router, which better called the P-600 series. Zyxel do not recognise it any more.
Default: Username: admin
Password: 1234
Default gateway: 192.168.1.1
http://pctechnotes.com/how-to-configure-zyxel-p-600-series-with-pldt-mydsl/
Jun 04, 2013 | NetGear DGND3300 RANGEMAX DUAL BAND...
I need installer for my Zyxel router P-600 series
http://www.zyxel.co.uk/web/support_download_result.php
http://www.us.zyxel.com/Support/Download-Library-Result.aspx?mif=20050627163311
You can go to the above mentioned websites for downloading the installer that you require. You got to select the appropriate model number. Only then it will provide you manual, firmware, software etc. for downloading.
For further clarifications, revert!
Thanks for asking,
Regards,
Arvind S Iyer
Sep 30, 2010 | Zyxel Prestige 600WH Wireless Router...
I got a router zyxel p-600 series n the cd is broken do we hve a programe for tht online thnks
Hi Simply go to http://www.zyxel.com/ select your modem , then click Support and Drivers , Then download all required Drivers.You should be alright then.good luck
May 22, 2010 | Zyxel P660HW-D1 Router
I using zyxel P-660R compact series but I can't logging to my broadband because error 815
error 815 is a dial up error. open control panel, then internet options and click connections at the top. remove every connection in this list. Your pc is trying to use a dial up modem and not a router.
Apr 11, 2010 | Zyxel Prestige 660R Router (P660R)
ZyXEL Prestige 600 Series router failure
Not sure which specific router in the series you have but the following may help:
Well there should be a power light on and solid green, a DSL light solid green and on. The internet and ethernet lights should be blinking green if sending and recieving data.
I'll bet thats amber and not orange. In which case you have a 100mbps conenction to between the pc and router.
Check here for more details.
Aug 28, 2009 | Computers & Internet
Do you have a zyxel series p600, 660R-D1 dsl modem user manual? I have one and have a range of kbps of 3050 to 240 kblps. I thought I would read and see what to expect, Earthlink and the phone company...
The user manual or user guide of the 660R-D1 is available on the zyxel.com site, if you go into the following path:
Support and downloads --> download library ---> up at the right hand side top you see a drop down menu with list of products, choose 660R Compact series. This brings you to the download page and you can choose out
Model :
P-660R-D1
Version : 3.40
Language : English
OS : N/A
Release Date : 07-14-2006
Citating the part from the manual that I think is important (see down at the bottom of this post the speeds, and the note that it may be influenced by your ISP standard. Ask your ISP what they use.):
1.1
The ZyXEL Device is an ADSL2+ gateway that allows super-fast internet access over analog (POTS) or digital (ISDN) telephone lines (depending on your model).
In the ZyXEL Device product name, "R" denotes an integrated router and "D" denotes a chip set standard.
Your ZyXEL Device product name ends with a number. Models ending in "1", for example P660R-D1, a denote a device that works over the analog telephone system, POTS (plain old telephone service). Models ending in "3" denote a device that works over ISDN (Integrated Services Digital Network). Models ending in "7" denote a device that works over T-ISDN (UR-2)
1.2
The DSL RJ-11 (ADSL over POTS models) or RJ-45 (ADSL over ISDN models) connects to your ADSL-enabled telephone line. The ZyXEL Device is compatible with the ADSL/ADSL2/ADSL2+ standards. Maximum data rates attainable for each standard are shown in the next table:
ADSL:
Up: 832 kbps Down: 8Mbps
ADSL2:
Up: 3,5Mpbs Down: 12Mpbs
ADSL2+:
Up: 3,5Mbps Down: 24Mbps
Note: if your ZyXEL Device does not support Annex M, the max ADSL2/2+ upstream data rate is 1,2Mbps.
ZyXEL Devices which work over ISDN do not support Annex M. The standard your ISP supports determines the maximum upstream and downstream speeds attainable. Actual speeds attained also depend on the distance from your ISP, line quality etc.
Please let me know if the above answered your question:)
Jan 26, 2009 | Computers & Internet
Oct 30, 2008 | Zyxel Prestige 600WH Wireless Router...
Zyxel Prestige 600 series
List of user guides for Zyxel modems: http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729
Jul 26, 2007 | Zyxel Prestige 841 (91-004-226010) Modem
Zyxel Prestige 660R Router (P660R) Logo
22 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
