Question about Infinity BASSLINK Car Subwoofer
Digital amplifier module harman kardon 104 ds15000v
I have a Harman Kardon HK990 which throws an error #005 if I switch it on with a digital input connected. If digital input is not connected, it turns on without any error and all buttons work as expected -...
1.Is the fault caused by an optical or coaxial input or both?
2. Have you tried a Firmware Reset? (press "Level Settings" button & "Speaker 1" together.
3.Do you have a Service Manual (I have pdf!)
Nov 28, 2014 | Harman Kardon Harman HK 990 Amplifier
Harmon Kardon 3055
That should be answerable but first read the instructions they contain some amazing information. I can not help you because I have no idea of what you want to know.
Jun 08, 2014 | Harman Kardon Harman HK 990 Amplifier
Why Harman Kardo HK 3490 goes into DSP voltage protect mode
This amplifier can go into protection if one of the low ohm resistors on the power module that is soldered to the transformer is defect. Check out R951 and R952, they are both 0R47 (0,47ohm). They are often broken and measure some kilo ohms.
Apr 29, 2014 | Harman Kardon HK 3490
Speakers harman kardon buzz
you have interference from something too close to your receiver. or too close to a speaker. don't stack all your devices together.
Apr 20, 2014 | Harman Kardon Audio Players & Recorders
Hk 3490 receiver on protection mode....what it means and how to correct that
You can try a factory reset after checking your speaker wires for shorts. The procedure is in your owner's manual. This will most likely not resolve your issue. If you need further assistance, or would like to inquire about repairing your Harman Kardon, please visit my website at audioserviceclinic.com and contact me there. BTW, I worked for Harman, as Technical Support for all Harman, JBL and Infinity products.Thank you.
Apr 07, 2014 | Harman Multimedia Harman Kardon HK 3490...
It runs so hot why?
Possibly lack of ventilation or excessive volume through difficult speaker loads.
http://media.onecall.com/Image_Products/Harman%20Kardon/harman-kardon-hk990.pdf
See page 6.
IMPORTANT: When connecting two pairs of speakers, determine the impedance of each pair
by looking on the back of the speakers, in your owner's manual, or by contacting your dealer or manufacturer.
You can listen to two pairs of speakers at the same time ONLY if the impedance of EACH speaker is NOT LESS THAN 8 Ohms.
WARNING: Do not play sets of speakers simultaneously except as recommended above.
Amplifier may overheat.
Jul 09, 2011 | Harman Kardon Harman HK 990 Amplifier
I own my harman kardon 620 amplifier for about 8 years. Now the sound from the speakers comes on and off intermittently. I have connected and disconnected all the cables to the speakers but it still has...
The problem is in the audio circuitry, there are bad solder joints on the board that need to be addressed, from your description it is a intermittent issue with the sound. Since this a high end unit I recommend a top audio technician to work on your amplifier, and I suggest not using the system until it is repaired because the risk to the audio output parts getting damaged is high and they are pricey.
Jan 07, 2011 | Harman Kardon Harman HK 990 Amplifier
Sound card problem Dell
download from this link
www.lostmydrivers.com/
select sound card driver
select creative
select your model name and model no
Jun 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
680 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
