Question about Husqvarna Garden
What is the air gap on a victa lawnmower magneto
4 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin: need gap for magneto adj....
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 27, 2010
  • 4 Answers
SOURCE: Ryobi chainsaw magneto gap
The gap needs to be as narrow as possible without any actual rubbing of the rotor against the magneto. The spacing is not as critical as with spark plugs or points (remember them?) since unlike those gaps there is no spark jumping across this gap.
Generally, as long as the magnetic field is strong enough, the magneto will produce the necessary spark at the spark plug. The closer the magnets are to the coil, the stronger the magnetic field will be across the coil, and therefore the stronger and hotter the spark.
I have replaced magnetos and they are simple to install, and almost impossible to mess up if you do it this way. All you need is a piece of thin cardboard (not corrugated). I use a glossy business card without raised lettering (so it slides easily), or the like.
1) Rotate the flywheel so that the magnets are NOT positioned in front of the magneto, then loosen both screws of the magneto so it can move freely.
2) Insert the business card between the magneto and the flywheel such that the glossy side of the business card faces the rotor.
3) Then BEND the business card back over each side of the magneto (in other words away from the flywheel) so it stays fixed and can not move from side to side when you rotate the rotor.
4) Then while pinching the magneto and ends of the business card tight between your fingers, rotate the flywheel to position the magnets directly in line with the two sides of the magneto.
Note: The magnets will grab the magneto and try to move it. As long as the slippery side of the business card is facing the rotor and you haven't removed the screws, it should move fairly easily.
Since the magnets want to pull tight to the magneto, but the business card thickness is the same across the entire surface, this gives you an even spacing between both sides of the magneto and the rotor. Essentially, the magnets on the rotor do all the work for you. with regard to alignment. As long as the magnets (flat shiny polished square surfaces on the outer rim of the rotor) align directly with the two faces of the magneto, the alignment is automatic.
5) Once you have the magneto and rotor in perfect alignment, cinch down both screws in an alternating method, first just to where they start to grab, and then back and forth a few times until they are firmly tightened.
6) Now, unfold the flaps of the business card and let it move with the rotor instead. You should be able to rotate the rotor away from the magneto and the business card should slip out easily. It may stay where it was or it may slide out from the magneto - either way will work.
7) Once past the magnets, the business card should come out. You may have to move the rotor back and forth gently a few times to get it to come free. When you are done, the magneto should be in perfect alignment with the face of the rotor and the rotor should spin freely without any rubbing.
8) Confirm the above and then reassemble and go cut some trees.
Phil
Posted on Jun 01, 2010
Testimonial: "Thank-you very much, just as I suspected - had not come up with of an alternative to the feeler gauge so that was most helpful."
  • 173 Answers
SOURCE: my Stihl ms361c won't start. Want to check air gap
Pull off the side cover where the cord is.Make sure the keyway in the flywheel is not broke and flywheel has not turned.If flywheel did not turn the timing is fine.Too set the air gap you have to loosen the screws on the magneto .Slip a piece of paper or metal that is .010 thick between magneto and flywheel and turn flywheel until magnet pulls magneto down.tighten screws and reinstall cover.
Posted on Nov 30, 2010
Lawnmower won't start
1. Bad gas
2. Check for spark
3. If no spark check flywheel alignment and gap on magneto coil and flywheel
4. If spark is present and flywheel is aligned with keyway, check for fuel manifold leaks
5. Check carburetor for debris
Aug 06, 2016 | Garden
Victa lawnmower manual 460 Pro
You want a manual for a victa or are you looking for an answer regarding a victa? If you want a manual then a good lawnmower dealer can probably help, if not you can try www.buyamower.co.UK or f.g.adamsons
Oct 14, 2014 | Garden
How do I get spark
Make sure the magneto is not grounded and make sure the air gap between the flywheel magnet and magneto is set to specs. If air gap is too wide, it will be difficult for the magneto to produce an efficient spark.
May 07, 2014 | Poulan PP5020AV 20 in. 50cc Gas Chainsaw
Lawnmower manual FOR A VICTA TWO STROKE
With a Victa lawnmower you must be an Aussie!! Try Retrevo Manuals.com A bita dicken around but shift hot for all sorts of directions
Jan 04, 2014 | Sewing Machines
Plug gap for victa 2stroke lawnmower
Hi paul
Set your plug gap at .28 - .32
Mar 22, 2013 | Garden
Not getting spark to plug on eagerbeaver 2014
Jeffuxum:
The magneto is probably where the problem is. You'll need to pull the cover off of the motor and check the gap between the magneto and the flywheel. If the bolts holding the magneto have vibrated loose, the gap between the magneto and the flywheel will be incorrect. While you have the motor cover off, check the wiring to make sure you don't have a short in your ignition wiring and clean the air filter. I don't remember what the gap is between the flywheel and magneto, but .010 In. sounds familiar. Both legs of the magneto should be the same distance from the flywheel and they must not touch the flywheel at any point. I have used a matchbook cover between the flywheel and magneto while I tightened the magneto retention screws and it worked.
Jan 18, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the magneto gap for a 6HP Briggs & Stratton 12H802 series engine?
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Jun 10, 2011 | Briggs & Stratton Briggs Stratton...
Lawnboy gold series 10400, sn 4906038, failure to fire. Possible bad magneto. Looking for replacement part and magneto settings; i.e., gap between flywheel and the magneto. Any other tips appreciated.
You should be able to get a new magneto at any local lawnmower repair shop. The proper gap can be achieved using a standard business card. When you get the new mqagneto, turn the magnets on the flywheel to the opposite side away from the magneto, replace the magneto pulling it all the way back away from the flywheel and "snug" 1 or both of the mounting screws.
Now, turn the flywheel magnet to where it is centered under the magneto, insert the business card between the flywheel and magneto and loosen the screw you tightened earlier. Magneto will pull down tight to the magnet. Tighten both screws then rotate the flywheel to remove the business card
Sep 22, 2009 | Garden
It wont spark at all. No fire. Just put a new spark plug so that's not the issue. This lawnmower is only 1.5 years old. Thanks
Could be magneto bad, wire from magneto bad, ground on magneto bad, or the clearance between the flywheel and the magneto is rusted up if it was outside. Clean flywheel with sandpaper and set magneto gap using a match book flap.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
