Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Maytag mtg 9700 thermal fuse location - Maytag MDE9700AYW Neptune 174 Electric Dryer
3 Suggested Answers
SOURCE: Maytag Neptune Thermal Fuse Location?
Yes, I just changed thermal fuse on the same model . . . take off the front door, the front panel and there it is; attached to the vent tube with a flimsy bracket
Posted on Oct 08, 2010
Macmarkus
  • 2605 Answers
SOURCE: Can anyone please tell me where the thermal fuse
Hello Tom, welcome to FixYa.
I'll start by saying your post indicates it is a Maytag MDE9700AYW dryer. I'm not sure if you know this, but this particular Maytag is built by Samsung.
To address your question as to where the thermal fuse is located on your dryer, it is one the heater housing, there is a hi-limit and a thermal fuse. If the Thermal fuse/safety is gone, replace the hi-limit as well.
Here is a chart to identify which thermostat is which and it's location, the resitance value to check for and part number for replacement.
Once you've gain access to them you'll need to remove at least one wire to check the continuity...the values are shown in the above chart (basically it's either open or closed)
As far as part, there are a couple of places I prefer, on-line at "searspartsdirect.com" or "repairclinic.com".
**unplug the appliance and turn off the gas supply before attempting any service...safety first**
Let me know how you make out or if you require further assistance and I'll do whatever I can. Good luck.
Regards,
Macmarkus :)
Posted on Sep 02, 2011
Locate thermal fuse on maytag neptune dryer model # mlg2000aww
The thermal fuse is located on the front cover over the blower wheel housing in the front of the dryer, the part # is 33001762,good luck
Aug 24, 2015 | Maytag Dryers
The location of thermal fuse on maytage modelhye3658ayw
you need to use a putty knife to slide between the top and front covers about 4 inches in from each side to release clips,then raise cover up and swing upward and rest against wall so it dosent go too far and break the wire harness or fall down on you then near the left rear area behind the drum you will see the heating element,look down the right side of the element housing and the thermal fuse on a bracket on the housing
May 05, 2012 | Dryers
Can anyone please tell me where the thermal fuse is located for a Maytag Neptune MDE9700AYW
Regards,
Macmarkus :)
Sep 02, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer won't start
thermal fuse is the white platic fuse mounted to the exhaust about 6'' from the blower
easy to get to with a snub 1/4 '' drive
Sep 30, 2009 | Maytag Dryers
Gas dryer model 9700 with a he alarm code is not heating?
Hi
Thanks for using FixYa. Please check the things that could stop a gas dryer from heating:
- Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Maytag Dryers
MAYTAG DRYER PYET444AYW HAS NO POWER...IS THERE AN INTERNAL FUSE?
There is an internal fuse. It is called a Thermal Fuse. It is not resetable it is only replaceable. It is located in the back of the dryer. Unplug the dryer and locate the thermal fuse and replace it. Two wires conect the to it. Also I would check the breaker to the dryer. Thanks and good luck. I you need futher assistance let me know and we will get through this together.
Aug 24, 2009 | Maytag Dryers
Where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
