Question about LG LN790 GPS Receiver
My gps will not load past the first screen - LG LN790 GPS Receiver
Can't get past the charging screen
Have you tried to "restart" the GPS by pressing the reset key at the back of the GPS ?
Usually, the media files (pictures, videos, music, text) are loaded (copied from your source/PC) to the T-Flash (SDHC) card ... and inserted into the GPS. The GPS device will recognize these files (in their appropriate formats, e.g. music WAV or WMA9 files, movie AVI, WMV, ASF files, eBook TXT files, pictures JPG, GIF, BMP, PNG files) and display the selections in their (respective) interface screens.
Dec 27, 2013 | dealeurstore.com 7 Inch Touch Screen X100...
Turns On but not past the loading screen
Hello :
I recommend you to reset your RoadMate .
To reset your RoadMate please follow these steps :
1: Locate the button marked "Reset" on the left, right or bottom of the unit.
2: Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
NOTE : Please don't attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
This solution should help with your problem . If that didn't help , then I recommend you call Magellan service for help .
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Magellan RoadMate 1340 GPS Receiver
My sat nav 1300 won't get past 'loading maps'
IT WILL STILL BE UNDER WARRANTY BUT TRY A SOFTWARE DOWN LOAD FROM WWW.GARMIN.COM THEN TAKE IT BACK TO THE SELLER
Dec 18, 2009 | Garmin nuvi 1300 Car GPS Receiver
Magellan RoadMate
The map software has become corrupted..
Please rate my help++++Thanks for using FIXYA
Oct 09, 2009 | Magellan Roadmate 760 GPS Receiver
MY TOMTOM XL 330-S WILL NOT LOAD PAST THE STARUP SCREEN IVE TRIED HOLDING THE POWER BUTTON DOWN BUT IT STILL JUST STAY ON THE START UP SCREEN WON'T LOAD INTO THE GPS (PLEASE HELP NEED IT FOR WORK)
There is a tendency that the unit is not properly charge try to charge the unit for 3 to 4 hours by using a wall adapter and after 4 hrs press and hold the power button for 10 seconds then release.
Jun 09, 2009 | Tomtom XL 330S GPS Receiver
Can't get past navigator loading screen any suggestions? it's a Nav-Cam 2007
it sounds like a defective unit, but it may just be a corrupted SD card.
Aug 14, 2008 | Evesham Nav-Cam 7700 GPS Receiver
New GARMIN 660 Won't get past the Intro screen
Problem solved: I got through to Tech Support. They suggested a 'hard reset', which solved the problem: Put you finger on the lower right screen while you power up and it will do a hard reset---and it will get past the "loading maps" screen, where it had been stuck.
Dec 25, 2007 | Garmin Nuvi 660 GPS Receiver
Nextar x3-02
I just bought one P3. The SD card does not load the maps!!! I am going to return right away...
Dec 20, 2007 | Nextar X3B GPS Navigation System
Nextar X3B
let the batter die. then hold the reset button and plug it in at the same time. itll take a second but i loaded up for me after a couple seconds.
Nov 24, 2007 | Nextar X3B GPS Navigation System
LG LN790 GPS Receiver Logo
Top LG GPS Experts
Nater13
Are you a LG GPS Expert? Answer questions, earn points and help others
