Question about Acer Aspire One PC Notebook
Acer aspire one, the color is flashing and changing on the screen
The color is flashing on the screen and changing to a dull pink shade, you can still use it but it is like a strobe effect
  • 41 Answers
A dull pink color usually means the backlight is going out. You can test this theory by plugging your laptop into an external monitor. If the picture is fine, you know you have a bad LCD on your hands.
They are medium difficulty to replace, and they're widely available on eBay for $100-$200 (USD).
If you have any questions, please feel free to ask. I'll monitor this thread.
Posted on Jan 26, 2009
Screen turned dull shade of yellow and is slightly flashing. What do I do?
check the ic in the color circuit or the resistor that connects to the collector of the kine transistor.these components can be faulty.probably it is a module so you might need to replace the module that has on the color circuit check the transistor also.good luck.
Sep 25, 2011 | Mitsubishi WD-73732 73" Television
Pink screen abd pink lines everywhere
hi there.
for this, kindly check the BIOS mode of your machien first to know if the pink lines will still show there and if it still show then you may wanto contact your acer support to arrange a screen repair or replacment since issues like this are usually cause by dead pixels or display driver problem or display driver updates issues
you may use the given phone number below to contact the acer support if yoru screen shows the pink colors on BIOS so they can arrange a repair or screen replacment 800-816-2237
Feb 21, 2011 | Acer Aspire One Netbook 8.9" Notebook
I'm using an Acer laptop Aspire 4920. Yesterday a horizontal line appeared at the bottom of my screen. I line moves and changes color . The colors are pink and green. TQ. jane.
The line may indicate 2 things, your video card is corrupted or damaged, or or lcd monitor is itself damaged. Proceed to your local service center/supplier.
Goodluck
Tedmac
Sep 18, 2010 | Acer Aspire One PC Notebook
Pink color should be blue also flashing screen
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 22, 2009 | Acer Aspire One PC Notebook
Screen is bright neon pink!
Did you also replace the power inverter when replacing the screen???
Feb 13, 2009 | Acer Aspire 5610-4648 Notebook
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Laptop acer aspire 5550: pink screen
This is basically happens with a tft.Please check it with a experienced technicin or u can take to your nearest aser service station for repair or replaced the tft.
Regards
ucp_pru
Aug 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
White turns to pink on acer laptop
I had the same problem but the white color became cyan.
I "solved" the problem hiting the back of the monitor. I think that is a problem of contacts between the signal of the monitor and the pc.
I have an acer 5610z.
Juan Pablo.
Jul 28, 2008 | Acer AL1916B 19" LCD Monitor
Acer aspire 3680 MONITOR backlighting problem.
its u r laptop lcd problem.so please replace u r lcd
Jan 11, 2008 | Acer Aspire 3680 Laptop
Screen is pink
have you tried the video settings by right-clicking the desktop then properties>settings tab then either manually change colour support or go advanced. If it doesn't budge, try turning off the system, go to safe mode if it still has a problem, try reinstalling your graphics or video drivers.
Did you do anything in particular before this happened?
Dec 09, 2007 | Acer Aspire 5100 Notebook
Acer Aspire One  PC Notebook Logo
651 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
