My cherry mobile mic not working plzzz help me ASAP
SOURCE: The Cherry Mobile D23 all of the sudden the mic doesn't work
You have made it clear, your problem is with the mic. If you know how to replace it you can give a try, otherwise i would recommend you to take it to the repairing shop and get it repaired. It's will cost a maximum of $10 (rate varies with countries) including service charge. Universal Mic is the best, so if you buy one, ask for a universal mic. Good luck.
SOURCE: how can i fix the
Microphone check two feet found on connector, whether it is broken or not, if not, try to raise the foot of the microphone. clean with eraser if necessary, clean the gold pad on the PCB area that is contrary to the microphone, all the better. make sure you screw with tight binding and not gap.
SOURCE: how to turn on/off flashlight of cherry mobile d11
Just long press the "0" key on the keypad. Doing it again will turn the flashlight off.
SOURCE: forgot my password restore factory in cherry mobile d11
My Dear Brother:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
