I have a RCA 42 inch 1080 HD Tv. My son decided to change my color setting. Is there a way to get the factory setting back? I have been playing with the different tint, contrast and color settings. I still can't getting anything other than a bright yellow and a bright blue. I don't have anything red. Can you suggest a good ratio for each setting?
    Problem Solver:
  • 13 Answers
Well there is usually a tab in your pictuer adjusment screen that says reset. but if your tv doesn't have that tab i can give you a few adjustments.
first- your tint should remain neutral. so if it has a color scale of 1 to 100 it should be on 50
second- your contrast should be about 80% or what your eye likes. look at the black tones
when you are adjusting it.
third- your brightness would look good about 65% pay attention to whites in your picture
fourth- your color all depends on how your eye precieves it. so adjust it with out making the colors to
neon or too dull
fith- your sharpness should be turned down to about 15% to much gives the picture a grainy texture.
sixth- your color temp should be neutral or normal. if the tv gives numbers the selection that says 6500k is the best choice.
you could always buy a calibration disc for about $20 and that could help you even better because now you are using images targeting the individule adjustment.
you could always pay to have it profeesionally caibrated. ISF certified techs will come too your home and do all the adjusment with special color filters and light sensors to give it the best picture possible according to your room. i know best buy charges $250 for it
those are just some suggestions. and the adjustments i give you work greatest for me, so if you dont like the overall out come you can always tweek it to your eye. make sure you use a digital picture with a lot of color when your making your adjustments. i like using disneys "the incredibles"
Posted on Jan 26, 2009
I have a 42" Samsung HD Plasma 1080. Started going
Sounds like it may need to be serviced due to component failure which unchecked will get worse, it may be also worth try to reset it back to factory settings in its setup menu this should clear any software issues it may have, but I think its more possible a faulty part or parts which comes down to cost and is it worth it sadly?
Hope this helps.........
Aug 28, 2017 | Samsung PS42B450 42 in. HDTV-Ready Plasma...
My kids changed the color on my 61 inch RCA and now i cant get it back to normal. Everything thats suppose to be purple is brown and pinks are orange and yellows are pale. Everything else is ok a little...
Someone probably played around with the "Tint" settings in the TV menu. The easiest way to fix it is to go into the TV picture menu and reset everything to the default settings. There's probably one option for "Reset to Factory Default" or something along those lines. Since every TV is different with this, you should read your owner's manual to find how to enter the menu and find the reset button.
May 04, 2011 | Televison & Video
I have a toshiba flat screen 42 inch. i went to change the channel and now all i have is a white screen and no sound
Hello
The tuner card in your TV is not working I thinks. Anyway set the TV to its factory defaults. It will make all the setting to factory levels. If this also didn't helep you, repace the tuner card.
To restore the TV to its factory setting:
[1] Press Menu and open the SETUP menu.
[2] Highlight INSTALLATION and press ENTER. A new set of installation menu will appear.
[3] Open the SYSTEM STATUS menu. Hilight the SYSTEM INFORMATION, and press ENTER.
[4] Press [ => / [5] Enter your PIN code (or 0000 if no PIN code has been set).
OK
Apr 21, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Try to hook up ps3, great pic no sound on tv or receiver tv is 7 yr old rca 50 inch scenium. i have tried to hook this up 20 different ways , no sound. is there something in the tv menu that needs to be...
Tries the PS3 with another tv?Make sure is not the PS3.Tries go into the tv menu to do tv audio resetting,so it can go back to factory setting,see if that make the PS3 it responses.
Jan 23, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My tv goes from 1080 to 720 while I'm playing my ps3 how can I make it stay on 1080
You have make sure the game can run in 1080p first by looking at the back of the box. If it can, and you're using hdmi etc then simply do the following:
1. Go into display settings.
2. Select HDMI, then "custom"
3. Uncheck 720p and 1080i, leave 1080p selected.
4. Start up the game and double check it is on 1080p.
Otherwise, you're stuck because the majority of games are in 720p to avoid lag within the game.
Dec 10, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
I need an authorisation code to retune a 42 inch LCD full HD 1080 TV Product L42E77AZ TCLELE
The TV will display the signal it is being fed with and adjust itself according to the video signal resolution. The video source tells the TV what the resolution it should display. 720 in 720 out on the screen, 1080 in 1080 on th screen (if TV can do 1080p or 1080i).
What kind of signal you are feeding your TV with.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 02, 2010 | Televison & Video
My RCA 42 " LCD Is crazed. i USE THE REMOTE TO TURN IT OFF AND ABOUT A MINUTE OR 2 LATER IT AUTOMATCALLY TURNS ITSELF BACK ON. THE ONLY WAY I CAN KEEP IT OFF IS TO UNPLUG FROM POWER SOURCE. IS THERE A...
Check the sleeper timer is not on like 30,60,120 Mins.Turn the sleeper function off,should work.Not,go in ur tv menu,go to PICTURE,go down to reset the tv Tuner board,the setting will go back to the factory setting.
Jun 18, 2010 | RCA L32WD26D HDTV/DVD Combo
I have a 42 inch rca tv model WB22YX5 componet inputs dont work
Sometimes, these inputs get damaged by ESD, or stray voltages, and become damaged. You may just need to give the set a reset, unplug an leave for 5 mins or so, and try again, if still no go, see if there is anything, in the troubleshooting procedures, that can help. It may just be a board replacement, If you decide, to get it repaired, please first contact RCA head office, and ask for a referral, to an authorised service center.
http://www.scribd.com/doc/7581822/RCA-Chssis-CTC-175176177186187-TV-Training-Manual
May 05, 2010 | RCA L46WD22 Television
HD 1080 Series (WD-55809) - Color convergence issue
I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts)  but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
Dec 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
