Question about E-Machines W3503 PC Desktop
Need help reboot my computer
My computer has an virus and im trying to shut down the whole thing and reboot it overs again,before the computer comes up i hold down the delete bootton and shift at the same time and i get the menu and i dont kno where to go from there!
  • 3 Answers
If you just want to shut your system down, turn it off, then press and hold the on/off button in. The sys will eventually, after about 5-10 secs, turn itself off. However, you will have to reconfigure your HDD and re-install your OS to get rid of the virus. Your best way to do that is to completely wipe the drive, then format it, prior to re-install. However, I would recommend you make a system disk before doing anything you the HDD. I would also recommend getting a copy of your sm bus controller driver from the hdd as there are a lot of us out here who have found it not on their recovery discs. These are your choices. Good luck to you.
Posted on Sep 13, 2009
  • 744 Answers
Hi.. first of all when ur system gets attacked by virus or threats its difficult to perform delete operations. The only best way is to format ur system with the help of XP cd. This XP cd will reboot ur operating system so that all viruses and threats available in ur C drive will get deleted... So the only option is to re install ur OS with XP cd...
thank u
Posted on Jan 26, 2009
My PC possibly has trojan:Win32/Rimecud.A virus which has affected my computer. It shuts down by itself after a command prompt appears on the screen really quick and restarts again - repeating the same...
Hello, reboot your computer into safe mode with networking by pressing F8 before windows loading screen. (You should see a black and white menu) Once in safe mode try to goto www.malwarebytes.org. Download, install and run that tool. It works pretty good at removing viruses, spyware, Trojans etc...
Chris
Jul 06, 2011 | Computers & Internet
My computer recently got a fake Microsoft security virus, the whole thing is shut down to the point I cannot access any programs that could delete it. It won't even let me get on the internet! And now,...
Boot into safe mode.
F8 before Windows boots.
Scan with Combofix for example.
Scan system files (OS cd needed)
To use the System File Checker, follow these steps:
  1. Close any open programs on your Desktop
  2. Click on the Start button
  3. Click Run
  4. Type this command in the Run box: SFC /SCANNOW
  5. Click the "OK" button
Jun 12, 2011 | Computers & Internet
I think I may have a virus but I'm not sure. When I start-up it says "windows has encountered a critical problem" and then it restarts. But then it keeps restarting over and over and over again. And I cant...
Follow the steps below to restore Windows then run your virus scanning software-
1. Shut down the computer.
2. Turn the computer on and immediately press F8 repeatedly until you get the "Advanced Boot Options" menu.
3. use the down arrow to select "Safe Mode" and press enter.
4. Window is should start with a "Help" window.
5. In the help window there is an underlined "What is System Restore?"
Click on that and "Click to open System Restore"
6. click on that and a new window comes up recommending restoring to a previous state.
7. Click ok and the operating system should restore your computer successfully and reboot into normal mode.
Thanks
Aug 07, 2010 | Computers & Internet
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
Computer turns off randomly
This is the problem of the wrong RAM working... likely ur RAM has been spoiled try to replace and check it .. your issue will be solved.
Jun 22, 2009 | Acer Aspire E650 PC Desktop
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Gateway notebook
it keeps rebooting but successfully reboots ?
One thing you can try is to set it so it does NOT reboot on errors
Aug 27, 2008 | Computers & Internet
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
HELP!!! Computer stopped working when anit-virus was installed?????
Assuming you are using windows xp. 1. Boot up into windows safe mode by pressing the "F8" key during boot process. 2. Choose "Safe Mode without networking" on the menu and after entering your desktop a pop-up will appear telling you that you are using windows safe mode, just press "OK" then uninstall Norton Anti-Virus. 3. Shut-down and/or reboot computer. Another alternative would be to boot into safe mode and perform a system restore. If you choose to do this, you still need to uninstall Norton Anti-Virus because a system restore will only fix just system files not programs that were installed. In other words, you will have a partial installation of Norton Anti-Virus in your computer. As to why this happened, could be a compatability issue with the use of Norton and some other program. Good luck.
Jun 07, 2007 | Sony VAIO Z1VAP1 (PCGZ1VAP1) PC Notebook
Computers & Internet Logo
121 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
