Question about GE WJSR4160DWW Top Load Washer
The main control setting ge 17505749p005 m298 i need this part
It does no work i try to set to a setting and it just spin
4 Suggested Answers
  • 93 Answers
SOURCE: GE refrigerator/freezer
Need to check voltage coming from control. If no voltage you need to replace main board on the rear of ref.
Posted on Jul 17, 2008
  • 512 Answers
SOURCE: I have a dual handset GE 2.4 GHZ telephone set.
Swap batteries and see if second hand set will work. Can get new battery or a different hand set on eBay.
Posted on Sep 03, 2009
bobicehouse
  • 1524 Answers
SOURCE: I have a GE refrigerator (model # GSH25SGRESS).
Change the control. GE has a number of problems with the original boards.
Posted on Dec 29, 2010
Manually drain GE WPGT9350C0PL
You can try removing the hose from the drain in the wall, place it in a pail on the floor, set the control panel to spin, even though the drain pump might not be working, there is a chance the gate valve is working and will allow it to drain.
If not, you need a small pump that attaches to a drill and two garden hoses, or a shop Vac.
Apr 02, 2013 | GE WPGT9350C Top Load Washer
Washer is not washing not spinning, its not working, what part doest it need
Unless the washer is checked in detail the exact part cannot be confirmed as you are the witness to the fault.
However it is possible that the control panel, the main program controller and the main motor must be checked to confirm the status.
If the motor does not receive voltage check the program conttroller, if Yes the mpotor needs to be checked.
Dont forget to check the door switch which if faulty will not turn on the set.
Oct 19, 2010 | GE WBSR3140DW Top Load Washer
I have a GE heavy duty 24 hour timer model no. 15075. I need to know what the dial in the middle needs to be set at and why does it spin? What purpose is the spinning dial serving. If it did nothing I...
The middle dial is the current time and it works like oldy timer does you set when you want it on then the timer will spin according to the time of day Duhhh
Mar 15, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Washer only spins
Have you tried to unplug the machine, sometimes the control boards can get stuck and if you unplug it for say 30 seconds then plug it back in, it may reset itself. otherwise you may have to call someone these are very complicated machines.
Jun 19, 2009 | GE Profile Prodigy WPSE4200A
Timer and washer will fill water to level but will not wash
HI, if the timer is not functioning, this is caused be a main control board chip set failure. you will need to replace the main control timer/control in this unit.
The timer/control initiates all the wash commands and, if it malfunctioning, it will cause these symptoms you are experiencing at this time..
Jun 02, 2009 | GE Washing Machines
May 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE-WBSE2090A2WW
your main control board is bad ( Electronic Timer) if you need one let me know I can sell you one at whole sale but i would need model number to get the right 1
May 22, 2008 | GE WBSE2090A Top Load Washer
Final Rinse
im a repairman and just ran into that same problem on the ge washer. the problem is the control board. That control board is expensive, but it will fix the problem
Feb 02, 2007 | GE WJSE4150B Top Load Washer
GE WJSR4160DWW Top Load Washer Logo
51 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
