Question about Audiovox RCA EZ209HD Small Wonder HD Camcorder (Black)
Ez209 battery doesnt work
My battery pack wont run longer than 15 min. I need to open the camera to replace battery, or can I run it another way. USB port turn camera functions off, no option there.
How does this camera take videos?
If I understand your question correctly, you are wondering how to connect this camera to an AC power source to do long term video capture. This would also be helpful for bulb exposure. Unfortunately, natively this camera does NOT support power over an AC outlet (240V or 115V in North America). Best solution I can find is to build a battery pack for it, but that might not work as I think the camera requires the battery door to be shut to function. You could likely build a battery pack and make it work, but you would likely need to do some case modifications.
If you want AC powered camera, you normally need to step into the higher end DSLR's (the mirror-based DSLR cameras). I do not believe that any of the PEN series has power over AC or over USB.
This camera supports up to 7 minutes recording in Video mode (due to an AVI limitation). I think the limitation is moreso in the compression algorithm used, but 7 min is the max it will record so having AC power isn't really required in my opinion. Bulb mode photography goes up to 30 minutes, so that may require some fancy power adapters. If you took the camera apart and swapped out the crystal for a slower cycle crystal you could get longer video and bulb exposure at the cost of no longer having an accurate clock or if you hack the firmware, but neither method is supported by Olympus (nor me) and goes beyond the scope of the original question.
At the time of this post, the E-P5 was the latest in the PEN series and that one does NOT support power over AC or USB.
May 19, 2014 | Olympus E-pm1 Pen Digital Slr Camera w/ M....
Fuji av 100 wont power up
Reset the camera by removing the battery for 15 mins, replace the battery. Switch on the camera and go into the camera's menu to set the Date & Time.
Mar 22, 2013 | Fuji Photography
D1oo Nikon enel3 lithium Battery packs stopped working
Batteries don't live forever. When handling them correct they can survive 1000 charge and discharge cycles. When taking an average of 200 pictures per charge, the battery could survive the camera shutter.
Try to use a battery till it is almost empty. The camera will give a warning when you need to replace (or charge) the battery. When you want to go on a trip or need to make a series of foot's you should take only charged batteries. When you don't use a camera, for a longer period, don't leave the battery in the camera. It could start leaking and damage the camera. But when the battery was not used for a longer period, please charge it before using it again.
This could help you to keep your batteries in better condition and let them live longer.
Dec 06, 2012 | Nikon ENEL3 Lithium Ion Battery Pack
I want to reset my camera
Remove the battery for 15 mins then replace the battery. The camera will go back to the factory defaults, go to the camera's Menu and set the Date & Time.
Sep 10, 2012 | Olympus EVOLT E-500 Digital Camera
Wont turn on
well maybe there is the lince stucked what you can try plugg it to a usb cable and that to a extern cable to the charger cable for usb once you see the light you take the usb cable out of the fotocamera should open now . but propably the fotos have on the side some damage -
Apr 17, 2012 | Nikon COOLPIX S5 Digital Camera
Hood support rod, ground out on the battery, engine wont run
unplug the neg. and pos. cables for about 15 mins and put them back on then wait 5 mins and then try starting it.
Jan 16, 2010 | 1994 Volkswagen Jetta
Can u charge camera with usb cable from computer
The Kodak camera that I own states in the manual that you can charge the batteries only with the printer/dock or separate battery charger. I've left mine plugged into USB for hours at a time and never noticed a charge going into the battery. I use both AA lithium-ion batteries and the pack that came with the camera. The Li-on AAs work as well as the pack and for a cheap price, I purchased 4 AA and the charger (about $15).
Nov 28, 2009 | Kodak Easyshare M753 Digital Camera
Battery does not work when its off the charger
The battery will no longer hold a charge. It needs to be replaced.
Sep 02, 2009 | Microsoft Xbox 360 Wireless Controller
Canon powershot doesnt work at all now!
Most probably weak batteries (this can happen even if new batteries are used). Recommend rechargeable NiMH batteries for the A400. See the following:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Mar 31, 2008 | Canon PowerShot A400 Digital Camera
Audiovox RCA EZ209HD Small Wonder HD Camcorder (Black) Logo
Top Audiovox Video Cameras Experts
NOEL
NOEL
Tony Parsons
Tony Parsons
Are you an Audiovox Video Camera Expert? Answer questions, earn points and help others
